|  | Home > Technical > Fault Code 4021 .... |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | There is an accelerator position sensor which has 6 wires going to it down by the pedals. Check the connector and it's corresponding connector on the Engine Control Module for starters. If you go through life with your head in the sand....all people will see is an ar5e!!
 Treat every day as if it is your last....one day you will be right!! | ||
|  18th Dec 2014 5:12pm |
| Frankie Chou Member Since: 18 Dec 2014 Location: To Kwa Wan Posts: 3      | Thank you.. will try it ...
 but i have got the other problem is .. when i use the diagnostic computer to clean the fault code.. yes it works, but when i drive the vehicle forward or backward, the TC light always suddenly on and off, also the ABS pump turn on as well.. coz i heard the sound from ABS pump for sure. At the same moment .. the left front wheel is locked by ABS pump, the steering wheel just turn left by itself.... also the break pedal has got vibrateion. Is it same problem with the accelerator position sensor ? | ||
|  18th Dec 2014 5:41pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Have a look through this thread it may help.     http://www.defender2.net/forum/topic2394.h...termittent If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  18th Dec 2014 5:59pm |
| Frankie Chou Member Since: 18 Dec 2014 Location: To Kwa Wan Posts: 3      |  THANK YOU SO MUCH!! u got facebook? | ||
|  18th Dec 2014 7:08pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | No....Social media apart from this forum I do not partake in. It eats your life.      If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  18th Dec 2014 8:17pm |
| Posting Rules
