Home > Maintenance & Modifications > V8 engine options
Page 1 of 3 123>
Fozzauk
United Kingdom 2016 Defender 130 Puma 2.2 HCPU Santorini Black
V8 engine options
Just had news from the garage that spark plugs in cylinders 6 and 8 are covered in oil. Looks like either the head coming off or bite the bullet and change the engine?
I am leaning towards changing the engine, but I am unsure what will fit? At present it has a 3.5 carb V8. I would like to stick with a V8 and go bigger if I can? I have seen a few 3.5 and 3.9 EFI engines on the bay but also some 4.6 V8's out of a P38, would the P38 engine go in with out too much hassle? Can this be mated up to the defender manual gearbox or would I need the P38 box?
As the engine is potentially coming out I have also dug out the Puma cdci bulkhead that was gathering dust in the workshop and might as well fit that at the same time. It was going in my TD5 DC before that was stolen Big Cry
I want to make sure I get this right because I don't fancy doing this twice!
Any advice/input would be much appreciated.
Post #379989 18th Dec 2014 4:09pm
TJ101
Best option if it was me
Find a late Disco 1 with a 3.9 Thor engine (serpentine belts) You will then have the Ecu,loom etc etc, to swap over (plus the auto box Thumbs Up )
Forget going P38 lump,, the 4.6 had known block problems, plus you would need to sort a engine management system out, like Megasquirt or simalar California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #379992 18th Dec 2014 4:25pm
Romadog
Late Disco 1 route...
or
Go 50th Anniversary defender / P38 Range Rover route with 4.0 or 4.6.
The latter is how mine is done. Plug and play rather than joining wires and hoping it works long term.
yes there are some negatives, but you can get an old 3.9 from a Disco that blows its head gasket soon after refitting.
50thdefender loom(RHD Japan) is what I have. It contains, engine, autobox looms. Then 50th Defender bulkhead loom has wing looms already in it, similair to Td5. I've updated the dash centre and warning lamps, really easy, just need to be patient and methodical.
Post #380003 18th Dec 2014 5:11pm
K9F
Is it burning much oil and smoking? I had a similar experience with #5 cylinder and it was due to the valve stem guides. It smoked blue on start up and as a result used a little oil but did not smoke or burn oil on the run. I was advised to leave well alone until it started burning oil all the time. The only drawback was that due to excessive carbon build up on that cylinder I had to remove and clean that sparkplug on a regular basis. Lasted another three years like that. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #380006 18th Dec 2014 5:20pm
Fozzauk
If you give it some good gas on start up then it throws out quite a cloud of black smoke.Seems fine when running and warm though?
I bought it as a project from a guy on disco3 so haven't run it long enough to see how much oil it's burning through. On the plus side it passed the MOT only needing a number plate light.
I quite like the idea of going down the 50th anniversary route, as Romadog said i'm concerned about an old disco engine blowing soon after fitting and having to start again. Are the 50th looms readily available?
Post #380029 18th Dec 2014 6:13pm
uncas
Black smoke is air to fuel ratio. Blue smoke oil.
Uncas
Post #380052 18th Dec 2014 7:22pm
Stue5
Italy 2005 Defender 110 Td5 USW Alpine White
I had the 4.6 Thor in the p38 1999 had no trouble only the heater matrix went funny after I sold it, it's still going strong lpg and all, sold at 119,000ish miles. I read the castings were beefed up in the later 4.6 engines to rectify the porriouse block. Range Rover p38 4.6 99 lpg(gone Sad )
Post #380073 18th Dec 2014 8:59pm
Grouse
If changing the engine and reliability matters - then no question go the 3.9/4.0 efi the rest are over stressed and suffer more from slipped liners etc
Post #380083 18th Dec 2014 9:29pm
Fifth Horseman
3.9 is physically a straight swap, did that with my first 110. Also if you get the loom and ecu with the engine then fitting the whole efi system is not too difficult, there are usually a few wires in the loom that will not be needed in the Defender application.
The main challenges are arranging the air inlet plumbing along with airflow meter and filter and providing the high pressure fuel supply from the tank.
TBH the carbs are a right pain to keep in balance and using an efi system results in a much smoother running engine with better economy (until you use the right foot Very Happy ).
I started out with a standard 110v8 with Stromburg carbs, then tried SUs, went to using an early efi setup off a classic RR, then when that engine died, fitted a 3.9 with the hotwire efi system.
Post #380085 18th Dec 2014 9:35pm
mikeh501
this is the one im putting in mine Mr. Green
still no idea of the problems im yet to encounter lol. ignorance is bliss.
Post #380112 18th Dec 2014 10:19pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
I think you would be better off having a EFI v8 (3.9-4.6) with the later serpentine belt. There will be a few changes coming from a 3.5 carb but the it is worth the effort. JE Developments sells a stand alone harness in case you go 14CUX. m
Post #380224 19th Dec 2014 11:10am
dazzx10r
stick a chevy LS in there job done Wink or be a little more creative and get super reliability go for a Lexus V8 Cool That's the beauty with Defenders the engine choices are huge, I've seen one guy on Landyzone fit a BMW M5 motor in one!
At the end of the day it's all down to how far you're prepared to go with it.
Post #380463 20th Dec 2014 3:29pm
Fozzauk
At the moment I am leaning towards a 5.0litre tvr chimera engine I have seen. I have quite a few spares for my wildcat with pretty much the same engine so this makes sense with my man logic. Laughing
Anyone done this before or have any advice on going this route?
Post #380504 20th Dec 2014 7:04pm
keith
X2 for the TVR .
Post #380506 20th Dec 2014 7:21pm
dazzx10r
Post #380752 21st Dec 2014 7:04pm
Page 1 of 3 123>
