![]() | Home > Off Topic > blow lamp recommendations |
| lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006
As part of the ongoing tool porn fetishism I'm looking for a blow lamp that will get stubborn bits of car hot enough for undoing but that is compact enough to get into some of the tighter spaces, also the cartridge's need to be cheap to keep the ongoing cost down. Any in particular worthy of a look? Rhubarb and custard let fly with their secret weapon.
I have seen one by campinggaz that claims 1700deg plus but I am guessing that is the flame temperature and not how hot it will get the work piece. Like you said though it has to help. Rhubarb and custard let fly with their secret weapon.
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
1700 degrees would be flame temperature.
Get a good quality plumbers blow torch as they are designed to work 'upside down' awkward angles without going out. Brendan |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060
I've got
http://www.screwfix.com/p/rothenberger-sup...orch/68635 Andy |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
2nd vote for Rothenberger
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
If you are not cutting & only looking to heat to free off seized nuts then that sounds like plenty hot to me. Just stick with propane as the best compromise on heat vs cost. |
| uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340
Look in the Cromwell catalogue they have quite a selection including the Rothenberger. I have a very small hand held one thats refillable from gas lighter cartridges, But I also have access to Oxy Acetylene equipment for the really big stuff.
Uncas |
| Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756
Had that Rothenburger one for a few years now and it is miles ahead of any other blow torch out there. I have used it to heat 12mm bar to cherry allowing it to be bent easily to a very tight angle. The Map bottles last for ever and I am still on my 2nd one after many years of reasonable regular workshop usage. Expensive, yes. Quality worth paying for? Undoubtedly.
| steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767
use MAPP gas with the rothenburger blow lamp
| kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403
+1 Rothenberger and Map Gas. It is a very nice bit of kit
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5142
It does not matter which torch you have it’s the gas that is important the best gas on the market is Ultragas forget about CampingGaz or Map gas.
Ultra Gas has a gas mixture of propane, butane and acetone to give a flame temperature of 2,100°C. It also has a foam insert to enable the cartridge to be used upside down for longer periods. http://www.tooled-up.com/product/sievert-2...0g/140177/ |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058
Provided that you know what you're doing, an oxy-propane or oxy-acetylene torch is unbeatable, but you may have insurance issues in a private setting.
You can cut and weld, braze, and generally heat things. The downside is that you're careless or don't know what you're doing you can incinerate or kill yourself and others with ease. |
It's not just about the gas it is also about the torch. The rothenberger has a fairly small flame, most other torches have a bigger flame. I also use mine to light my open fire, but as a plumber I've got a few.
Andy |
| All times are GMT |
