![]() | Home > Technical > 3/4 hood fitting on td5 pick up |
| NickH Member Since: 01 Nov 2014 Location: Halifax Posts: 204
Hi mate
I had the same problem, turned out I didnt have all the bits. I will post a pic of the inside of the hood at the back of the truck cab in daylight tomorrow. have you got the piece of angle iron and the channel ? 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
thank
i have gav channel and angle aluminum |
Sounds like you have the right bits
I riveted the channel to the back of the truck cab, I had to make the channel because I didnt have it. The angle should have slits in it which allow it to slot in to pockets in the hood and then you push the hood and the angle into the channel groove. Dont know if that makes any sense 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
makes any sense all right
its how the channel fits the tuck bode |
sorted
| All times are GMT |
