![]() | Home > Maintenance & Modifications > Fuel cap photo request |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
I didn't mean drilling more holes Steve...
![]() Just adding a second cord to the one you already have... ![]() There must be a way of fixing or 'welding' a fixing to the Defendoor?... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
Easier said than done, yes you can put a hole through the Defendoor with a rivet or something but it doesn't look as nice.
Also, unless it's plastic (the rivet) if it does come off the side it will certainly damage the paint by scratching. And I'd rather I lost the Defendoor than that. I think that they are made of EPDM if I ree,her tightly. |
I use a length of fishing wire tied around the filler neck and tied too a small hole made in the top lip of the defendoor. You can't see it when it's on, it won't rust and You can leave the defendoor to dangle of it while your filling up.
Ray |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3796 ![]() ![]() ![]() |
Don't know about that retaining strap?
Unless there is someone to hold the cap whilst filling up, it rests against the paintwork, which does not impress me at all. Solution?.....Wifey gets out as well at fill up time & holds the cap! Silly, but true. Pickles. |
If you gently place it against the body there will never be a problem, if it's chucked off and allowed to hit or move about on the side it would cause scratches eventually.
^^ Steve.... It indeed isn't more complicated than that. And if I would ask the mrs to hold the fuel cap for me during filling up,.....
![]() ![]() ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Wrong! Found in the end I'd needed to use a 6.5mm drill bit. Fitted no no problem: ![]() Click image to enlarge |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 ![]() ![]() |
Thanks Steve, my husband is about to get his drill out so that's really useful.
Mmmmm mince pies???
I do not understand this fuss about how NOT to lose your Defendoor. All the ideas about fishing line, gluing straps on, using wife etc etc. I know full well what Barbara would say if I suggested she got out of cab to hold the Defendoor. Let's just say it would be short and pithy! I have a very simple solution Step 1) Remove Defendoor with right hand Step 2) Transfer Defendoor to left hand Step 3) Remove fuel cap with right hand Step 4) Transfer fuel cap to left hand OR let it dangle gently off lanyard Step 5) Use right hand to remove fuel noozle from pump and fuel vehicle. Step 6) Finish fuelling, replace fuel noozle in pump and reassembly is the opposite of disassembly. NOTE if you are left handed swop left for right in instructions above. Believe it or not by following the above steps I have not lost one Defendoor yet ![]() There again feel free to leave your Defendoor on the pump/ground/rear bumperette etc. It just means more mince pies for me! ![]() Brendan |
Hole drilled and painted
![]() Just letting it dry and then it's job done. |
I know this is a fuel filler cap thread but the Defendoor was mentioned....
![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
