Home > Puma (Tdci) > Actual problem or just a defender quirk?!
Page 1 of 3 123>
Crafty1980
I've just noticed today that something's odd with my indicator stalk...
If I indicate right then turn the wheel right, the indicator stays on, then as i turn the wheel back to centre it clicks off... That's all correct...
Now if I inficate left then turn the wheel left, the indicator turns off... I have to re-engage it to carry on indicating... When moving the wheel back to the Middle again, the indicator turns off as it should.
So it's just the operation whilst turning the wheel left that doesn't seem to work properly... Or is this just a quirk of the defender???
Post #378226 11th Dec 2014 9:28pm
grafty99
Shouldn't do that, but I would say plenty fail. Both my td5 and my dads tdi do it. Same way round too Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #378232 11th Dec 2014 9:37pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Do you know if the steering wheel has ever been taken off? Check if it is center by turning it full in either direction. It should end on exactly mirrored angles. If not, could be the reason.
Post #378234 11th Dec 2014 9:41pm
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
Mine does the same but turning right at a roundabout. I have noticed that sometimes it stays on. I think it has to do with what position the steering wheel is at when you indicate.
Smile
Post #378235 11th Dec 2014 9:41pm
URBAN TRUCK
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Of the 130 plus defenders we have sold this year we have had a couple that did this ..
Its a faulty stalk that need replacing .. Should be no problem under warranty .
Simon
UT
Post #378239 11th Dec 2014 9:56pm
Crafty1980
Ah brill. Yes I thought it was a problem not a quirk! Will raise the issue with local LR dealer. Needs to go back and have a couple of other things fixed at the same time too! Cheers as always for the great response! 👍😄
Post #378249 11th Dec 2014 10:20pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Bought the 130 March 2013 and Im having indicator stalk problems from day 1. I don't know how many times it's been back for this. They even changed the stalk, but again, nothing solved.
I have sent them two videos recorded with a GoPro and politely asked them to study it and discuss it with Land Rover as this is annoying and above all, dangerous in crowded cities I regularly need to be.
What you have is probably just the start of the problems I have now. You don't want to hear the words I say when the stalk does things I don't want for the tenth time within 15 minutes of driving through Amsterdam. Evil or Very Mad
Post #378251 11th Dec 2014 10:25pm
munch90
The indicator cancal has nothing to do with weather the column is central or not
The cancelling ring is part of the switch and locates to steering wheel by pegs on the wheel
the cancelling ring has two cut outs in it , on the blue ring ( think its blue ) there is a arrow that needs to point the right way , it can be fitted 180 degrees out , the indicators will still work but there can be a different amount each way to cancel
not uncommon if someones had the wheel off and the ring has moved and someone lines it back up to refit wheel but doesnt know about the right postion of the ring
could may have something to do with it maybe .
Post #378259 11th Dec 2014 10:39pm
Crafty1980
I haven't had the wheel off... But now I come to think of it, I had a problem a few weeks ago with not being able to get the steering wheel to "lock" when the key was taken out... Could that have something to do with it?!
Post #378261 11th Dec 2014 10:45pm
munch90
Dont think the steering lock would have anything to do with it
Post #378264 11th Dec 2014 10:54pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
I took my orig steering wheel off and fitted a Wild Bear boss/steering wheel and did not bother fitting the self cancel roller pins
It does not bother me at nor do I notice they don't self cancels at all - but then I mainly ride a motor bike so as I'm use to use to canceling indicators manually Thumbs Up
Post #378664 13th Dec 2014 4:32pm
munch90
none cancelling is a mot fail now
Post #378673 13th Dec 2014 4:55pm
Iktank
Its down to who you know Wink
Post #378676 13th Dec 2014 5:02pm
Iktank
Dont think this is right - the warning lights on a dash all have to work correctly, the self cancelling it not a requirement,
Spoke to my Mechanic mate who ownes an garage and MOT bay and he would not fail self cancelling not working but would fail if the stork did not turn the indicators on and off correctly
Post #378683 13th Dec 2014 5:11pm
munch90
think your right I was thinking of self park on the wipers Embarassed
Post #378702 13th Dec 2014 5:51pm
Page 1 of 3 123>
