Home > Maintenance & Modifications > Waffle boards: where to put them?
Page 1 of 3 123>
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
I have owned a couple of WBs for quite a while now and they have been proven usefull.
However, on longer trips they are a bit af a nucence because I store them in the car: My roofrack is full with tent, water and jerrycans (see my gallery).
I would like to seem some photo's if possible of ingenious places you have put your waffle boards at. Preferably outside the car as muddy boards are a pain indoors.
At the moment I don't really know af a good place to put them and I would not want to have even more weight on top for obvious reasons.
Post #378137 11th Dec 2014 4:57pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
It depends how many holes you want to drill but I always think they look convenient fixed to cargo restraint systems on the side panel of a 110. I think there are some pictures on the mud uk website. 2002 110 td5
Post #378141 11th Dec 2014 5:14pm
Jimb1978
Post #378142 11th Dec 2014 5:17pm
SailingTom
In next months LRO magazine it looks like there fitting a no holes required mount to the side of the chap with the G4 defender from the patriot roof rack Smile
Or you could put them on the spare wheel with a custom mount Defender puma dormobile camper
Post #378145 11th Dec 2014 5:20pm
stu_007
These are excellent and don't require any drilling of roof rack;
http://www.mantec.co.uk/productdetail.cfm?...9C877AD271 Current
2021 D110 HSE
2013 D90 XS
Previous
BP07 OZR D110 (1930 YBA)
2007 G4 Mongolian Recce Vehicle
BP52GHZ D110
2003 & 2006 G4 Event Vehicle
Post #378151 11th Dec 2014 5:44pm
zone30
Not convinced of either solution, sorry. They would disable access to the 2nd row passenger door:
Post #378195 11th Dec 2014 8:00pm
leeds
You already have a lot of weight up top, so some possible suggestions.
Waffle boards are heavy especially when full of mud, am guessing could be 20kg+ apiece
1) Put a false floor in the rear load area, chop 200mm? off the length and slide under the false floor.
2) Mount on rear spare wheel, but consider some extra support.
3) Since you are running a pre 07 vehicle, mount them on the bonnet close to the bulk head. Think that would be special one off brackets
4) Mount them at the front but underslung from the roof rack.
Brendan
Post #378202 11th Dec 2014 8:25pm
g-mack
That's not pre 07 Shocked My 109 thread
my youtube channel
Post #378216 11th Dec 2014 9:08pm
jst
been there, tried most options, they need to be easily accessable and not make everything muddy when you have used.
False floor is the only one that worked for me (with the exception of the trayback where i pinned them to the rear tray!) Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #378221 11th Dec 2014 9:18pm
zone30
1) have that and it's already full: poles and extras for foxwing, chairs and wrenches and stuff.
On top of tbat there's a alu plate, on top of which I have the travel boxes and recovery gear. I currently have the waffles under the boxes, but when dirty it becomes a bit of a mess.
2) I want to move the shovel on the wheel as it's a branch hook atm.
3) sorry, but it's a 2011, so no flat bonnet.
4) no room as they are the thicker HD kind (green), approx 1,5m long.
I'm playing with the thought to either mount them on top as I'm going to built an treeslider to prevent branches getting stuck between the tent an the cans, but again, extra top weight Sad
Other option is a thin drawer under the boxes and on top op the plate, but rather have it outside.
Corrent layout: if you look closely you can see one under the black box. My ass is in front of the other.
PS, I have a spare wheel carrier planned with hi-lift mount to get that thing also out of the car. Will remove completely when not greenlaning to keep it from rusting up.
The idea is to have quick and easy access and not getting my gear dirty in the car.
I do get stuck somethimes:
Post #378222 11th Dec 2014 9:24pm
leeds
Ooops Embarassed
Sorry my mistake, should look more carefully next time but chequer plate or is it a trick of light?
Puma bonnet kicks that idea into touch.
Brendan
Post #378237 11th Dec 2014 9:47pm
roel
Is it not possible to make a bracket between the roof and the roofrack? I don't know if you have enough clearance there. Roel
2003 90 Td5 (2009-now)
Post #378306 12th Dec 2014 7:48am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I put my WB in a couple of drawers as per the photo. The drawers are removable so if/when they get muddy I can take them out and wash they down. It's worked well and keep the weight low down.
Simon
Post #378310 12th Dec 2014 8:23am
Cupboard
would it be an option to move the jerry cans somewhere (where?) and put the boards up top instead?
Post #378331 12th Dec 2014 9:50am
leeds
A wing tank on RHS would add about 40 litres of fuel
A wing tank for water on LHS is about 40 litres.
A replacement main tank is about 120 litres.
That would get rid of need for jerry cans.
OK neither is a cheap option compared to a couple of brackets but something to consider??
Brendan
Post #378348 12th Dec 2014 11:17am
Page 1 of 3 123>
