![]() | Home > Puma (Tdci) > Fitting Melville Moon seat covers |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
you have to take out the front seat base(only the base seat). then it is very easy, but there is no instruction about that
David128 Member Since: 31 Jan 2010 Location: Melbourne Posts: 30 ![]() ![]() ![]() |
Tried that.
Sorry was not clear in my original post, I removed the seat and got the cover on but the seat will not go back in - the pins locate (just) but the seat does not clamp down at the front - it is not aligned. |
oh yes, i had the same problem. you have to push with power, don t be scared, i sat and i push with all my body
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 ![]() ![]() ![]() |
Yeah, you have to give it loads of welly!
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Hi,
I managed to 'lever' the base of the seat back in place by using the adjustment bar to move the seat back and forth and angling the seat at the back. However, ensure the 'pivots' on each side of the base seat engage into the slot in the rail - careful not to damage the plastic inserts. Good luck El pepe flamenco JLS 'El Pepe Flamenco' |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Pull the seat cover REALLY tight around the base - you'll be surprised how much you can stretch it. That way the majority of the fabric seams and fastners will be under the base.
Use LOADS of brute force but don't break the front locating sockets (it is quite hard to break them so don't be too precious). If you have heated seats then make sure the cable isn't caught around the edge. Once it's been on a few days then it all settles down. I left my passenger one unclipped for a few days (I wasn't taking passengers), re-tightened it and then fitted it. Now I can remove and refit the seat bases as if I didn't have covers on! One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
I have just fitted some middle row grey ones to my 110, they went on alot easier than that !
next month, rear 2 (in the boot) and 2 fronts ... not looking forward to the front 2 now (unless grey ones are easier to fit) ![]() fitted the middle row seat covers, no problem. However I have just ordered the front pair, delivery late Sept, early October ![]() |
