|  | Home > Maintenance & Modifications > 3.2TDCi 5 Cylinder Ford into a 200TDI Defender |
| MEJ999 Member Since: 25 Sep 2014 Location: Peebles Posts: 7    | Hi,
 What engine are you replacing? A Puma 2.2/4? Michael | ||
|  10th Dec 2014 2:47pm |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443      | I thought that was in the title of the thread so pretty much starting from scratch. | ||
|  10th Dec 2014 3:59pm |
| Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233      | How much of the original transit have you got, you will need
 Engine bay harness, dashboard harness, cluster, fuse boxes, transponder, original key., throttle pedal and ecu. if you have enough of the donor transit with everything plugged in and powered up you should be able to get it running on the floor. I did warn you that this was no small job. It would be a lot easier if you had a running 3.2 transit to compare it to. Good luck with it. 90 300 TDI SW (sold) 130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility | ||
|  10th Dec 2014 5:54pm |
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456      | Hi what year Mendel engine have you used ?
 Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build | ||
|  10th Dec 2014 8:32pm |
| Rogermac Member Since: 10 Dec 2014 Location: Perth Posts: 3    |
 Its a Puma 2.2. | ||
|  10th Dec 2014 11:25pm |
| JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706    |                          2 something | ||
|  10th Dec 2014 11:26pm |
 right what have you taken the 3.2 from to put in your defender 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build | ||
|  11th Dec 2014 1:15pm |
| Rogermac Member Since: 10 Dec 2014 Location: Perth Posts: 3    | Its out of a Ford Ranger 3.2 tdci. Engine and gearbox is all fitted in the vehicle and we have the Ecu and wiring loom from the ford Ranger which has been modified for the fifth Injector.
 The ECU is a Siemens Sid 2008 and is the same ecu as fitted to the 2.2 tdci Defender it even has the same part no but when we opened them up the Ranger ecu has an extra chip on the board which I suspect is for the 5th Injector. I think the main problem is getting the ecu to talk to the body control unit. Roger | ||
|  11th Dec 2014 11:27pm |
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456      | For a start you would need all the wiring from a 3.2 tdci ranger as it runs as you say Siemens ecu which is different to the 2008 visteon ecu ? . 2015 2.2 tdci hardtop xs
|  12th Dec 2014 8:39am |
| Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233      | If you buy a transit ecu from Ford they all have the extra injector driver, they fit 2.2, 2.4 & 3.2. I would imagine the Ranger has a more complex electrical architecture than the Transit. Was the Ranger auto or manual. 90 300 TDI SW (sold)
|  12th Dec 2014 8:58am |
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456      | They don't it has to be a specific ecu for the 3.2 !!! And because it's the newer engine it needs the Siemens 3.2 ecu 2015 2.2 tdci hardtop xs
|  12th Dec 2014 8:15pm |
| Posting Rules
