![]() | Home > Technical > Spongy brakes when engine running |
Master cylinder seals,get some one to press the pedal whilst you look for fluid re-circulating thru the reservoir (which it shouldn't do). Pov.spec,ftw. 2006, 110,TD5.
souster4 Member Since: 11 May 2014 Location: West midlands Posts: 153 ![]() ![]() |
Thanks jimbob. Does the engine need to be running to test this?
Not really,but as it seems somewhat intermittent I'm guessin your gonna have to pump the brakes a few times to recreate the spongy feel (at which point you'll see bubbles in the reservoir),also look for black bits in the reservoir another sign the seals failed.As you recently manually bled the brakes it's probably that thats killed it.If you replace the mc you'll have to bleed it before connecting the brake lines otherwise your pushin a load of air back into the system. Pov.spec,ftw. 2006, 110,TD5.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5975 ![]() ![]() |
When I fit new calipers I like to bleed as normal, then pump pistons out a bit, clamp pipe, open bleed, force pistons back in caliper to make sure no air is trapped inside the caliper.
Andy |
Thanks a lot guys.
I'll check for bubbles in the master res then. If it does turn out to be the master cylinder, do you think rebuilding it would be satisfactory? Or a OEM replacement? And how do you go about bleeding the master cylinder before connecting it up? Lastly, do you still think eazi bleed is good enough? |
Rebuilding isn't as popular as it once was,I assume once you get corrosion inside the mc there is a possibility of it tearing the new seal,price up a new un. Lucas make the abs mc so you don't need to be robbed by LR (probably).Google "bleeding MC",there are a number of different ways,do which suits you,I fitted the new mc, filled the res and slowly pumped the brakes before re-attaching the brake lines.I also use Ezibleed,but they can still be a PITA to bleed properly. Pov.spec,ftw. 2006, 110,TD5.
Ive ordered a master cylinder rebuild kit (couldnt afford a new one) and vented discs. Fit the caliper spacers and then should be all good
I would be checking for play in any wheel bearings , that could give inconsistent pedal feeling
or bleed again master cyl problems are not that common , normally find people replace the master and say its ok now , but its the rebleeding after the cyl was fitted is what fixed it , not the cyl replacement do you get a better pedal when sitting still engine running then when been driven for a couple of miles ? best way is pump pedal couple of times sitting still , then leave for 1 min then try again if its spongy then good chance of air still in system , if its a descent pedal then could be play in bearings if you got play in bearings when you drive the wheel moves side to side (only slightly ) and pushes pistons away from disc and first press on pedal will feel spongy 2nd or 3rd get better |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8322 ![]() ![]() ![]() |
as above, my guess would be wheel bearings assuming the poor braking comes after movement? is it poor 2st press and then improve?
if your stationary and press the pedal and its firm does it stay firm or does it ever drop on repeated presses without the vehicle moving, engine off? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
