Home > Maintenance & Modifications > How do you keep yours dry
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Every time I go out for a bit a wading I end up with four goldfish bowls for headlights/spotlights. I have tried sealing them with sealant around the bulbs but that didn't really seem to work. How do you keep the water out or is it a case of drilling a small hole in the bottom to let it drain out once it's got in? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #377310 8th Dec 2014 5:49pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
If you don't mind having near useless headlights you could fit sealed beam units ! 2005 Td5 90 XS
Steve
Post #377326 8th Dec 2014 6:33pm
landy andy
Yep. That's what I've done. Spent ages trying to keep water out, then went the other way. Drilled a hole in bottom of light and let it run out.
Andy
Post #377327 8th Dec 2014 6:34pm
Dave T
Andy, how does that work, is the chrome still ok? What size hole did you drill?
Lou, having done the wiring mod and fitted crystal headlights with night breaker bulbs, I'd rather not go that way, although I wonder what they would be like with the wiring mod, anyone done that? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #377335 8th Dec 2014 6:47pm
landy andy
I've drilled 3-4 mm holes at the bottom of the headlights. First time I did it through the front lens of the crystal headlight, but once in very heavy rain and spray water entered the holes and blew both bulbs. So I now drill through from the rear.
I run crystals, and night breaker bulbs, not yet rewired them, but don't understand why that would make any difference. The only thing to remember is to turn off lights before wading, so bulbs are not hot.
Andy
Post #377341 8th Dec 2014 7:01pm
landy andy
You can just about see the holes
Post #377342 8th Dec 2014 7:06pm
Dave T
With standard wiring I was getting about 10.5 volts at the bulb, with the wiring mod I now get about 13.5 volts. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #377378 8th Dec 2014 8:10pm
landy andy
Why would that effect holes in the bottom of the lights, is the bit I don't understand?
Post #377380 8th Dec 2014 8:15pm
Dave T
Ahhhh, no, I meant to Lou, what would the sealed beams be like with the wiring mod Rolling with laughter Rolling with laughter 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #377385 8th Dec 2014 8:20pm
