|  | Home > Td5 > Battery selection |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | May help....    http://www.defender2.net/forum/topic29701.html?highlight=optima http://www.defender2.net/forum/topic26702.html?highlight=optima If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  7th Dec 2014 8:55am |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055  | When mine goes I'll be fitting a Bosch or Yuasa,the oem ones a very good tho.
 5 yr guarantee on (900 amp)Yuasa Pov.spec,ftw. 2006, 110,TD5. | ||
|  7th Dec 2014 12:06pm |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897      | My nearly ten year old 90's still running on it's second OEM battery.   | ||
|  7th Dec 2014 12:22pm |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971      | What's the point of spending three times the amount of the OEM one on an Odyssey when the OEM one does a good job and lasts?
 The Odyssey has a high CCA for its capacity but it's not like you need to save every last inch of space in the battery box and if you accidentally leave your lights one then you may be thankful of the extra Ah you get out of the standard one. Someone at work has just got a decent branded (I think it's a Varta, that what they usually supply and he said it had a 5 year warranty) battery for his TD5 from our local auto electrical place for £70 including VAT. Unless you've got some particularly good reason to have something else, that's what I'd do. | ||
|  7th Dec 2014 11:09pm |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039      | My 90 is running on a Optima yellow top. I have a winch and I use it too. The Optima is about 10 years old and has problems starting my 90 if it has been standing still 4 weeks or longer. Shorter periods not a problem yet. Roel
 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) | ||
|  8th Dec 2014 12:48pm |
| Posting Rules
