![]() | Home > For Sale & Wanted > Now sorted. Utility side opening or old roller shutters |
| SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1733
Hi there if anyone has swapped to plain sides in an ex utility land rover like these;
http://www.ebay.co.uk/itm/Land-Rover-Defen...&rt=nc Click image to enlarge I dont mind buying the whole panel if i have to as above. Missed out on the ones linked as had a call out at work and had no signal. If not fire engine/ electric board roller shutters as long as there only in the side pannel (not down the tub) Im going to make a back for a double cab out of a land rover roof so a pair would be ideal or just one. The ones linked are ideal if anyone has any sitting around. Happy to pan for a pallet or collect. Cheers Defender puma dormobile camper Last edited by SailingTom on 15th Jan 2015 10:22am. Edited 1 time in total |
Cheers if you could that would be great, not to fussed by the space they use really. but the ones linked are the ideal solution. Always the way when you watch something for the week then no signal to bid
| shazzy90 Member Since: 17 Dec 2010 Location: tyneside Posts: 489 |
I once put side lockers into a truckman top ,very easy to make ,I sourced the frame and doors from a catering van builder ,about £90 for the pair then used the panel I cut out bonded onto 12mm ply for the insert into the door framing,hinges were also from the catering manufacturer,gas struts from bq kitchen range,if I was to do it again I would have the doors hung on bottom ,ie dropping down with restrictors fitted so the door acts as a table at 90 degrees to body I will try to dig out some photos
| Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111
I sold these April this year, it gives you an idea of the size..............
Click image to enlarge Click image to enlarge Click image to enlarge why do my photos fall over Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Range Rover p38 4.6 99 lpg(gone ![]() |
Thanks Guys, either of those types would also be ideal. Im liking the roller shutter, have to look out for a set now. They seem perfect for what I want to do.
If I dont find any though or have any luck on here Ive found the perfect excuse to tour the local burger vans |
| Andy80 Member Since: 31 May 2013 Location: Essex Posts: 492
A new project? Don't the fire brigade have roller shutters on their tenders?
Id happily take them off the pump at the moment
Nice quick way to get to stuff, Plenty at work about the right size just none on the market |
| Andyred90 Member Since: 30 Mar 2013 Location: Wantage Posts: 482
Tom,
If you contact Nevets22002 on Landy Zone he found a company in Birmingham that made a set for him and from memory the company specialises in Horse Box fabrication. I can drop him a PM if you like. Good luck Andy |
| Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861
Horse box windows will do you for you.
| alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 729
Tack box doors is what I'm putting in mine, on ebay for £100 brand new from horsebox building company, they do come up now and then.. Series 3 88" side panels fit perfectly, fitted one of mine in the cold today!
Cheers. Alex |
Thanks Guys keep the ideas coming. Im in no real hurry so keeping a look out for some roller shutters and price up some done to fit if the Company Andy said still do them.
Ive got a series roof lined up ready cheers Alex Think it should be worth the effort as opposed to a truckman top purely for the aspect of standard roof racks fitting and should still look in keeping. Opening sides are a must though like my soft top is now A few possibilities now as Leenorthants horse box windows/ lockers look the right sort of sizes to and a good price; http://www.transportwindows.co.uk/index.ph...amp;p=ecom |
