![]() | Home > In Car Electronics > Retrofit heated seats |
Our Heated seat wiring kits are totally plug and play and come with comprehensive instructions.
They are for use with OEM seat heaters that can be bought from a variety of suppliers as above. Thank you |
Hi Steve,
Drop me your email address and I'll send over a PDF of the instructions in the morning |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
MikeJ Member Since: 04 May 2014 Location: Dorchester, Dorset Posts: 41 ![]() ![]() ![]() |
I fitted the Waeco kit to my old 90.
Definitely recommended and simple to do. They worked just as well as the factory ones in my current 110 - arguably better because the Waeco ones have two heat settings. Mike |
![]() It's what I hoped it would be. How easy / difficult are the heater pads to fit? |
Instructions were in the box.
Basically, carefully slide the seat covers from the foam insides and stick the pads (sticky tape supplied) on the seat bases and backs. Then replace the covers. Wire-up - relays and switches were provided in my kit - I put them either side of the clock on the mud console ![]() Click image to enlarge |
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 ![]() ![]() |
I fitted the Waeco kit in mine,highly recommended!
I've bought the wiring kit. Yet to hear from Matt just yet.
Once I saw the instructions and quality I was sold. ![]() |
Thanks Steve,
All received, will be on its way to you tomorrow ![]() |
Thanks.
![]() I'll leave the pads just for now though and look at that a little later on. Is there different versions? I thought I'd seen a MSH200 too somewhere. |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
just fitted some heated leather puma seats in my 90 best upgrade i have done.
How much did they set you back?
�500 including delivery
�44 for wiring loom �5 for new connectors �10 for mini fusebox did have to buy new centre dash �39 Steven ![]() Click image to enlarge before picture, still got locbox to go in |
Not a bad price.
