Home > Puma (Tdci) > Fwd LR Service Bulletin SSM38792 2.4 Puma Engine knock noise |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
It sounds simular to dullbirds ongoing problem 2.4 90 XS
6th Jul 2009 11:25am |
Bogblaster Member Since: 04 Jun 2007 Location: Glawstershire Posts: 119 |
Thats right Cannonball, only under load, but not drive train related! Kicks in at 1750 ish and runs off at 2000.
Have spoken to my local LR dealer, am awaiting a call back. 2019 MY Disco 5 HSE Lux Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
6th Jul 2009 2:03pm |
shorty Member Since: 31 Oct 2008 Location: Hillcrest, Kwa Zulu Natal Posts: 160 |
Bogblaster I bet you a fiver they tell you its completly normal, characteristic of the Tdci motor Land Rover's don't leak oil, they simply mark their territory!
6th Jul 2009 2:30pm |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 |
Let us know what your LR dealer comes up with Bogblaster. I would agree with shorty.
6th Jul 2009 2:41pm |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 |
Bogblaster / Cannonball,
Just found this thread. My 09 110 is doing the same with regards to knocking between 1500-2000rpm under load. Took a new 90 for a spin to compare, and it was much, much quieter. I am about to get a new clutch, so there is a possibility that it may be related. Any news on your fix, if LR managed to fix it at all. Last edited by robharvey on 4th Aug 2010 12:53pm. Edited 1 time in total |
4th Aug 2010 12:07pm |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 |
Mmm! Might be similar to an issue I have. Pinking noise after an upshift. Not always though. One of those annoying intermittent faults that never occurs when the dealer has the vehicle. My guess is it's engine management related. If the dealer ever sorts it out, I'll post the outcome. Don't hold your breath though!!!
4th Aug 2010 12:47pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1568 |
I have a similer problem. Mine smokes like a trooper when its starts from cold. Then it makes some right knocking noises. Its a 10 plate with 3000 miles on. Its going in on the 11th over night so see what happens!!
4th Aug 2010 8:10pm |
lyon99 Member Since: 05 Jun 2010 Location: Perthshire Posts: 20 |
I have the same noise when cold a knocking till its warmed up its a 10 plate also. I will need to get it looked at, And see if the local dealers will do anything about it, And they will look at it and say there is nothing wrong with it as they always do. 110 Utility puma 2.4 2010
110 pick up 300 tdi 1998 Fendt 716 Vario |
4th Aug 2010 10:25pm |
I'll wager you get better service from your Fendt dealer.
5th Aug 2010 8:11am |
Further to my knocking issue which a couple of you seem to have had. Turns out that Cannonball's (informed)guess was correct, at least in my case. A bolt in my fuel pump had come loose causing a high pressure fuel leak. Dealer has tightened up and it seems back to normal. It also seems to have cured a juddering I got when coming to a stop - almost as though I was going to stall. |
9th Oct 2010 8:29am |
Stafford landrover fixed mine with an ecu upgrade. Runs great now. Have got up to 7600 miles. The engine still does the odd strange thing. But on the whole is ok now.
9th Oct 2010 9:41am |
