![]() | Home > In Car Electronics > I phone 5 Pairing to the Alpine Head Unit |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
Have you tried removing the paired items from both lists and starting from scratch? ...
![]() It would also be sensible to shut down Blue Tooth on your iPhone and start it again when in your truck and ready to pair... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
Is it listed as compatible for your specific head unit? If you go through life with your head in the sand....all people will see is an ar5e!!
captain slow Member Since: 22 Jun 2011 Location: Herts Posts: 357 ![]() ![]() ![]() |
It works on mine, but as suggested above I had to remove previous pairings before it worked. 2.2 Tdci 110 XS CSW Corris Grey
Prince Harry's D3 (gone but not forgotten) 300 Tdi 110 CSW (gone but not forgotten) |
I believe the Alpine units only accept up to x3 pairings as a max...
Michaels Defender Member Since: 16 Aug 2007 Location: North Yorkshire Posts: 285 ![]() ![]() ![]() |
Thanks, when I unpaired my old Nokia, (which I kept in the 110 all the time and was always charging when the ignition was on) the iphone connected OK, but I could not have the two paired at the same time as that was my plan
I think that pretty much goes for most, if not all in-car units...
![]() Would confuse the poor things to have two connected at once... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
Barrowboy Member Since: 05 Oct 2014 Location: Frodsham Posts: 82 ![]() ![]() ![]() |
Always fun and games when I join the wife in her car (which used to be my daily drive) because the bluetooth always defaults to my phone, not hers. Drives her up the wall! |
