![]() | Home > Td5 > Jeez TD5 Headlights Are S£$% |
| ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277
I've just recently done the loom upgrade and what an impressive improvement, my head lights are now brighter then my genuine land rover spot lights, so I will be upgrading them now instead of my headlights.
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
I currently run 100 watt headlight bulbs and find the lights a fine, have bought the headlamp loom upgrade to preserve the switch but haven't had time to fit it yet. 2005 Td5 90 XS
Steve |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2789
They're only rubbish if they are poorly set up or maintained.
Mine has normal bulbs in Wipac crystal units and the upgrade loom, result is lights that are truly excellent. Total cost about £50 and no stupid f***ing LED things stuck on the front of the car |
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Crystal wipacs and osram nightbreakers made a world of difference for me ! And I'm soon to fit the relay loom too I'm expecting a very crisp white light from it. I cannot recommend the crystals enough they really do turn the lights from candles to torches
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6735
Or even just get new Wipac Quadoptics. The lights on my new XS are so much better the 15+ year old Cibies on the soft top.
New Quadoptics can be had from about £14 each. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042
Crystals with Philips bulbs for me, very good upgrade.
No doubt the loom upgrade would improve things but I've not done it myself. |
| EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156
Crystal headlamp units.Osram Nightbreakers and the loom upgrade is the way to go. really pleased with the result. All due to info gleaned from previous posters on this forum
| Tank Member Since: 25 Jul 2014 Location: Fife Posts: 444
Thanks for the replies which ones do I get ? Any links
Crystals: http://www.paddockspares.com/pm678-wipac-c...ralia.html
Philips bulbs (H4size) http://www.ebay.co.uk/itm/PHILIPS-X-TREME-...3a975b6378 Possible new headlight wiring kit: http://www.paddockspares.com/boomslang-per...-loom.html The headlight wiring kit is new, just noticed it myself just looking on your behalf. It does look good but I'm impressed with just Crystals and bulbs on mine. The wiring loom kit would up the voltage a little possibly as there are voltage drop issues with standard wiring in some cases. Best to check that manually. |
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2279
Checkout the PIAA range of bulbs , costly but I'v always used them .
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18051
A more significant benefit of the harness upgrade is that it prevents the otherwise inevitable failure of either the main light switch or the dip switch, which always happens at the worst possible moment.
Cheers custom90steve will order tomorrow
| epictrail Member Since: 20 Sep 2013 Location: High Wycombe Posts: 395
These bulbs OSRAM NIGHT BREAKER UNLIMITED are also very good and cheaper. £12.20 a pair
http://www.amazon.co.uk/gp/product/B00EPLC...ge_o02_s00 |
| Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492
Osram are the ones I have with crystals and home produced loom. That is a very very good price for the bulbs.
1994 Def 90 300tdi |
| All times are GMT |
