![]() | Home > Td5 > How to remove td5 steering wheel |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
Undo the center nut. stand in the driving position and put on the wheel it should come off.
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2268 ![]() ![]() |
Make sure you don't end up with a Broken nose
/\ Too true
Have you figured it out yet Brad ?
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
I bought a tool off eBay for a few ££'s. Works a treat, I've used it several times, it makes removing the wheel a doddle.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5976 ![]() ![]() |
Loosen center nut but leave on, put knees under bottom of wheel, and a hand on the top of wheel, pull wheel with knees and hand whilst giving the center shaft a good tap with a soft hammer. That's my method, if pulling doesn't work.
Andy |
DefenderJon Member Since: 01 Dec 2012 Location: Sunny Ulster Posts: 68 ![]() ![]() ![]() |
I have a removal tool here. You're more than welcome to borrow it (by post, obviously...) ![]() Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!! |
td590brad Member Since: 30 Nov 2014 Location: Sussex Posts: 203 ![]() ![]() ![]() |
So do I prize the Land Rover badge out and expect to see a nut ?
Thanks |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 583 ![]() ![]() ![]() |
Yup,prise the Landy badge out carefully with a flat blade screwdriver.Undoo nut,but dont take it off completely.Then try any or all of the above,et voila.Hopefuly,it will be off.
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5130 ![]() ![]() ![]() |
Be careful if you use the hammer method as the shaft is collapsible.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6682 ![]() ![]() ![]() |
Having BIG trouble getting the wheel off the soft top, it's completely and utterly jammed.
Have tried a puller which pulled the threads out of the wheel ![]() Plus Gas hasn't unjammed it. Can't apply heat as the wheel will melt ![]() ![]() ![]() ![]() ![]() |
How many splines and what steering wheel do you have. I have seen a few Defenders where some nutter in the past who owned the Defender has hammered on a 36 spline steering wheel on to a 48 spline shaft and once they do that it is near impossible to remove….
http://www.web-rover.co.uk/nav.php?p=articles/steeringwheels |
That my old web site, I did the original research into these wheels
![]() It's got the correct (36 spline) wheel on ![]() ![]() ![]() |
I have to say thank you then Martin as that web page over the years has come in very handy indeed
![]() Glad its not a hammered on wheel anyway ![]() If all else fails trying to remove the steering wheel you could try a freeze spray. Then let it thaw, it just might break the grip of the two types of metal. |
