![]() | Home > Puma (Tdci) > My15 carpets |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6700 ![]() ![]() ![]() |
Exmoor do list one, I had a quick look under the premium range.
It's a shame there isn't an "over the arches" rubber mat for the Puma SW, I've got a genuine NAS one for the square arches in the soft top and it's great. ![]() ![]() |
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 ![]() ![]() ![]() |
Can you send me a link Martin, I'm still struggling to find it. 15 plate 2.2SW XS
Iain Member Since: 09 Nov 2014 Location: Aberdeenshire Posts: 79 ![]() ![]() ![]() |
The one I was looking at was:
http://www.exmoortrim.co.uk/store/defender...etail.html But good point about the ridged arches, spray adhesive and shape them over a deadening layer? The carpet would be: http://www.exmoortrim.co.uk/store/defender...etail.html Wright offroad do a rubber chequer plate if you were a dab hand at cutting straight lines to make your own. I'm not and would like a machine to cut it neatly. |
I see, yeah I saw that one, I was just trying to find somewhere that makes a rubber version of the carpet trim, ready to install. It looks like I'm going to have to buy a big roll of rubber and attack it with a knife!! 15 plate 2.2SW XS
Sorry Matt, I hadn't read all of your previous posts, I was referring to carpet not a one-piece rubber mat.
You might be better off adapting the mat I've got in the soft top - STC4629 ![]() ![]() |
EastFreo Member Since: 24 May 2014 Location: Perth Posts: 103 ![]() ![]() |
I recently put some closed cell foam matting I bought in a camping shop (it was a double camping foam mattress) in the rear cargo area and plan this weekend to put in some marine carpet over the top. Already made a significant difference to noise and I can lift it out to clean and dry.
I have a standard Land Rover mat over the top as well. I found heaps of advice on the www.aulro.com site including this. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8379 ![]() ![]() ![]() |
i have the Exmoor trim acoustic matting in two vehicles, works really well.
have carpet in the 110, that works well, and not wet either, and its used as it should be. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Might buy the carpet set you found and use that as a template to modify the loadspace mat once it goes nasty, (probably about a week!!) 15 plate 2.2SW XS |
Let us know how you get on
