![]() | Home > Puma (Tdci) > Fuel Tank Breather |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2503 ![]() ![]() ![]() |
the small hose on mine had to be replaced. Bad quality rubber I would say. Puma 110" SW
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
I cant deny i was a little shocked it broke where it did...i expected a tank out job, but again a little shocked Mike
how did you notice it had broken Mike and where did it break 2.4 90 XS
The one way valve in my breather went a couple of weeks ago and was replaced.
I noticed it because the front of the fuel tank was covered with diesel. Bob |
Top Chassis rail bit (where it hooks under the tub) and i noticed because i looked...ok well not at it I was giving a top up of waxoyl, but it had almost broken all the way through and the pipe seemed reasonably brittle at a few points i could feel whilst taping it up Mike
