![]() | Home > Maintenance & Modifications > LED's for Dash |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
Nice and bright.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
What LEDs did you use, how many do you need for all gauges and speedo? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
It's a good mod, I think you need 4 - the clock doesn't use one (annoyingly) and the speedo uses 2.
You can buy a kit on ebay - with all 4 LEDs for either old or TD5 spec Defenders. I still struggle though with the fuel and temp no matter which LED I put in, at night time I still can barely see them. This is due to the original pre-TD5 Smiths gauges being utte crud when it comes to illumination. Hence I'm switching to VDOs eventually ![]() |
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 ![]() ![]() |
I bought 5, one for each gauge and 2 for speedo as said. I haven't wired up one of my gauges yet though.
![]() http://www.ebay.co.uk/itm/land-rover-defen...4616f889ac 2007 Defender Puma Tonga Green 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
Dave k Member Since: 29 Feb 2012 Location: Cheshire Posts: 151 ![]() ![]() |
I must I'm a little late with this one.
(I have neglected the old bus of late!) I've just fitted LED's to my dash, & even in daylight you can see a difference. Just a couple of observations, Do it in winter, as long sleeves will cover the gouge marks in your arm where you've struggled to negotiate the rear of the clocks. Do try to do this mod if your index finger has had close contact with the blade of a magimix the previous day. It can be a bit tender, plus it's mucky behind there, & your plaster will get very grubby! Ex RN 110 Station Wagon Never Raced or Rallyed |
Dave
Did you buy your bulbs recently. The original supplier I got them from have sold out. If so where did you get yours from? Cheers ![]() 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
I have got some Green Led's from Steve at Advanced Factors in my 110 as I wanted to keep the original color.
I haven't got a pic with me at work but will post one up later! Be warned though, the larger size plug ones are on order (I belive) as the ones I originally got were the thinner version which does fit but is too small and can fall out! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Try
http://www.ebay.co.uk/itm/Land-rover-Defen...513446407? Other LED providers are available ![]() Never Raced or Rallyed |
Cheers Chaps
That's a great help ![]() ![]() 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
