Home > Puma (Tdci) > Grease for UJ's
CapeLandy
South Africa
Grease for UJ's
Hi Lad's
Anyone got a manual at hand and can give me the type of grease for the prop shaft / UJ's?
Thanks in advance.
James
p.s I managed to buy a relatively cheap little hand held grease gun to reach the front prop shaft grease nipples which are placed such that the fitting on the end of the normal grease gun cannot reach. Puma 110 - gone
Series III 1973 - going strong
Post #3745 10th Sep 2008 2:12pm
mse
Re: Grease for UJ's
as with all landies you need a flexi head one Mike
Post #3747 10th Sep 2008 4:32pm
Eduardo
Lubricants for drivetrain:
Engine Transmission
Castrol BOT 130M
2.4 liters
5.1 US pints
Transfer Box
Castrol Syntrax 75W-90
or
Texaco Multigear 75W-90R
2.3 liters
4.8 US pints
Front Differential
Castrol EPX 80W-90
or
Texaco Geartex EP85W-90
1.6 liters
3.4 US pints
Rear Differential
Castrol EPX 80W-90
or
1.6 liters
3.4 US pints
Sorry but the grease to be used in the UJ are not specified in the workshop manual Sad
If can help, transmission uses Grease ESD-M1C220-A
Regards Eduardo
Post #3748 10th Sep 2008 5:10pm
Laurie
Any high temperature grease will do - Graphite loaded is probably best.
Post #3754 11th Sep 2008 12:43am
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Curious, but why a high temp grease? I've always used an NLGI No.2 Lithium or Lime based grease.
Had to turn two of my U/Jgrease nipples to get the gun to fit.
Don't forget the two sliding joints!
I found "little and often" seems to work best (grease in, crap out).
Bosun.
Post #3761 11th Sep 2008 7:18am
CapeLandy
South Africa
Thanks all. Puma 110 - gone
Post #3767 11th Sep 2008 9:01am
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
I've had many problems finding the right solution to greasing the props but the one that works using a standard grease nipple adaptor is to:
1. jack all wheels off the ground
2. Place the centre diff in neutral
This allows the shafts to be turned independently allowing you to find the best position to attach the grease gun.
Hope this Helps Rich, Very Happy
Post #3791 11th Sep 2008 7:13pm
CapeLandy
South Africa
grease gun
This is the smaller gun compared to normal head
don't think this grease will do though?
 Puma 110 - gone
Post #3793 11th Sep 2008 7:38pm
Laurie
Bosun.
I've never come apon a lithium grease that wasn't 'high temperature' - will do OK
Post #3805 11th Sep 2008 11:16pm
mse
got some in a spray can from Halfrauds good stuff Mike
Post #3815 12th Sep 2008 5:58pm
