![]() | Home > Puma (Tdci) > My15 carpets |
| Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288
If you opt for factory carpet it will be everywhere.
| Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180
That's why I opted out of it, I'm sure I read somewhere that the front had rubber trim, must have imagined it. To order the carpet parts for just one wheel arch side costs more than the factory fit option without the other wheel arch and floor piece. 15 plate 2.2SW XS
| adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299
Factory fitted carpet covers both front and rear everything
The only reason I went for the carpet option was to cover the rear arches. As well as protect the painted finish the carpet helps to cut the noise from wet roads, which is now bearable |
If my understanding is correct, on MY13 SW XS defenders there was not a carpet option LR were just giving a rubber trim, if so did this cover the loadspace area, and if so does anyone know the part numbers for those bits?
I'm after a rubber trim throughout, but as a last resort rubber front and carpet in the loadspace, I'm just shocked at the prices for these bits aftermarket. 15 plate 2.2SW XS |
There has always been a carpet option, from the moment it was not standard. Most people did not pick up on it.
Really, so? http://www.defender2.net/forum/topic17551.html 15 plate 2.2SW XS
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752
Can only speak for 110 SW, But carpet option for 15MY is the same when that were standard XS fitment in 2011
All covered, f & r foot wells, seat box, tunnel, rear load floor and wheelbox's California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
| Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
Just wait till that carpet gets damp and starts stinking.
Don't see the point of having carpeting other than for a very minor contribution to dampening the noise levels. Zero regrets at just having specified the rubber mats in my 14MY SW - says the man who has just cleaned out his vehicle after a couple of weeks of wet muddy feet going in and out.. |
I don't really want carpet in the back, just want something to cover the bare metal on the wheel arches between the rubber mat I have for between the arches, and where the window trim comes down to. I just wanted something off the shelf rather than have to make something fit, I haven't ordered the carpet option but was beginning to think I should have, but if the carpet covers the front as well I'm glad I haven't ordered it cause that wouldn't last long at all with me before it was trashed.
I'm sure however if rubber trim was supplied by lr for the rear, even for a short time in my13, it must be possible to buy this trim from somewhere as a ready to install part. Just need someone who actually owns one of these to confirm if lr actually did trim out the loadspace cause otherwise it is just a lot of speculation! 15 plate 2.2SW XS |
Not had one as yet, going back to one of the first TD5's , saying that, never had a Puma that leaks ,, Main Brian James Trailer Dealer for South West UK |
| SS90 Member Since: 16 Nov 2013 Location: Uk Posts: 372
I opted out of the carpet option for the same reasons, I suppose it depends how the vehicle is used. Is far more practical without carpet, but considering a large percentage of Defenders aren't used as they were designed to be they probably don't see much mud or dirt |
| Iain Member Since: 09 Nov 2014 Location: Aberdeenshire Posts: 79
Would the exmoor trim sound deadening load space kit suit? rubber, protective and has a go at reducing noise.
I have a 15MY Utility on the way and, like you, I am looking at options to protect but also make for a more comfortable passenger area for longer runs. Exmoor carpets for passengers and then the rubber load space kit perhaps. |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6732
I'm going to be putting Dynamat in mine, so need something to cover it over in the back.
Site sponsor LRI solutions have a rear carpet: http://www.lrisolutions.co.uk/index.php/la...arpet.html They do a 110 version as well as full carpet sets. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Thanks Martin, hadn't looked at them, will be a lot cheaper than buying genuine parts. Why don't one of these companies produce a rubber version, there must be a market for it? 15 plate 2.2SW XS
| All times are GMT |
