![]() | Home > In Car Electronics > Installing stereo from scratch |
| Orangesofa Member Since: 10 Oct 2014 Location: Somerset Posts: 214
I've just recently collected my 2013 2.2 Puma 90 which had no stereo installed. I pulled the dash off yesterday and found this taped (with the aerial lead) to a metal upright towards the back of the dash.
Click image to enlarge I assume this means I have the loom and can plug this into the back of the head unit which I believe had the corresponding socket (it arrives next week). I would appreciate help/advice on two aspects of this install: 1 - I have popped the speaker grilles off in the footwells and there are no speakers and no obvious connectors. If I have the loom, will I also have the speaker connectors? If so, what am I looking for? 2 - As there was no stereo installed - just a blanking plate, there is no cage to slide the new h/u into. Any ideas what I secure a cage to behind the dash to stop the whole lot slumping down behind the heater controls? Any advice on installs would be much appreciated. I am not into ICE in a big way - no subs, amps etc - just plain and simple h/u and speakers under the dash. Thanks, Phil |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Twice I've posted this link today.....
If the link works and you can read a wiring diagram you will have everything you need here.......... http://api.viglink.com/api/click?format=go...Bwdo%253D1 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 30th Nov 2014 12:49pm. Edited 1 time in total |
Perfect - link now working!
Edited it.....works for me since editing!
Oooh - Lots of pretty coloured lines....
So I am looking at page 51 and this tells me the colour of the wires I need to look for - right? I will go and have another look under the dash and see what I find! Any help on the cradle would be much appreciated or even better - some photos of how they do it on a factory fit! |
Page 51....Bang on the nail....
A standard DIN cage where you bend the tabs out is fine. Many head units you will get the cage with the unit. Factory unit is different. Depends what unit you are fitting, but the connector should fit or with Alpine you can get an adaptor connector. http://www.ebay.co.uk/itm/like/14073188845...p;ff14=108 Any half decent automotive/ice provider will sell them. Halfords do 'em too. Treat every day as if it is your last....one day you will be right!! |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698
What head unit are you fitting?
If not the original, then you will need an adapter loom as per http://www.defender2.net/forum/topic29061.html 1988 90 Td5 NAS soft top
2015 D90 XS SW |
I have gone for an ALPINE IDA-X305S.
This is a pic of the back so any help with connectors I need to buy would be appreciated http://images.sonicelectronix.com/images/421646/big/idax305s.jpg |
The help with the connector is already in the last post of the thread Martin linked to.
Just go on E-Bay and search for the item mentioned. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks guys - I think I have all I need.
I have ordered the PC2-117-4 harness adaptor for 2013 onwards. It does come with the cage so will have a look at how to install when it arrives and I will get outside and have a nose about at speakers wires! |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
You might find this useful too: https://www.defender2.net/gallery/thumbnails.php?album=1018
