Home > Off Topic > Key fob interference
Fullfat
1999 Defender 90 Td5 HT Rioja Red
I posted this here as it's not for a defender, but wondering if anyone has any ideas,
My wife's suberu key fobs seems to only work intermittently, nothing too unusual but it seems the same for a number of cars that park outside my house, transit vans also suffer, cannot see its a coincidence as its happens to often but what is that could be the cause of interference on car alarms systems that would stop the fobs working ?
My wife car ever plays up when parked anywhere else.
Driving us mad as its no fun a 5 am!
Post #375177 30th Nov 2014 10:23am
K9F
Obviously as your problem appears to be geographical you need to consider local conditions perhaps?
Radio/television transmitter, mobile phone mast, electrical pylons, local radio ham operator basically anything local to your house that may interfere with the fob emmision. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #375183 30th Nov 2014 10:43am
munch90
I noticed my defender fob at home didn't work a couple of times when walking over to it , then noticed the electric gate opening and it was the wife opening gate with her gate fob killed signal from defender fob otherwise it works fine also it does did to discovery fobs as well , customer had discovery that wouldn't unlock when he was out on a shoot moved discovery and it worked fine , showed him what can happen by doing gate fob while he tried his fob and it done same thing
Post #375191 30th Nov 2014 11:01am
rallysteve
Most fobs are 433MHz which is quite a well used band. Usual culprits for interference on the band are cheap wireless doorbells (obviously intermittant) weather stations (intermittant), thermostats or most likely a (cheap) wireless cctv system
Post #375194 30th Nov 2014 11:12am
