Home > In Car Electronics > wiring colour
Mcmuffin
Belgium 2013 Defender 130 Puma 2.2 HCPU Santorini Black
wiring colour
TDCI puma 2008 :
I want to install a "master" relais and an additional fusebox for all my spots,usb,working lamps etc...
I want the relais to switch off the current when the engine is down.
What colour is the +12V-wire, and do I find it in the passenger under-seat box?
grtz,
Kris
Post #375114 29th Nov 2014 10:20pm
Martin
Site Admin
12V permanent or 12V ignition switched?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #375118 29th Nov 2014 10:47pm
Mcmuffin
ignition switched
Post #375119 29th Nov 2014 10:49pm
Martin
Site Admin
White with a green stripe Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #375120 29th Nov 2014 10:50pm
Martin
Site Admin
However I don't think on an 08 Puma that there is one under the seat Sad  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #375121 29th Nov 2014 10:51pm
Mcmuffin
some relais an fuses there and lots of cables
Post #375125 29th Nov 2014 10:55pm
Martin
Site Admin
I mean I don't think there is a white/green ignition 12V there.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #375126 29th Nov 2014 10:55pm
Mcmuffin
I'll check tomorrow. If not, I make a connection to the cigarette lighter.
Kris
Post #375127 29th Nov 2014 10:59pm
K9F
Mcmuffin,
If the link works and you can read a wiring diagram you will have everything you need here, it's a rhd set but it'll be the same colours:
http://api.viglink.com/api/click?format=go...%3Bwdo%3D1 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #375173 30th Nov 2014 10:13am
Mcmuffin
thx
Post #375225 30th Nov 2014 2:48pm
Vince VDB
France 2008 Defender 110 Puma 2.4 XS CSW Santorini Black
Yes there is one under the seat.
The brown/orange cables with a 15A blue fuse is 12V ignition. Very simple to find, there is only one cable with a single fuse integrated in the loom.
I think this cable brings 12V to run EGR motor, because there is 12V during 5-6 seconds after switch off ignition.
This is the brown/orange cable with the white strip.
on top of the pic
on bottom of the pic
 Defender 110 Puma 2.4 SW SE
Defender 90 300 Tdi SW with TD5 body
Land 90 V8 HT
Post #375229 30th Nov 2014 3:36pm
