![]() | Home > In Car Electronics > Wire Slicing |
Not an auto electrician but a marine one.....
![]() Hermetically sealed in-line splices are the best. There is a sleeve that is preformed with resin at each end that when you apply heat the sleeve shrinks and the resin melts making a 100% waterproof seal. I have bucket loads of these and can send you some in the post. You do need a crimping tool but you may be able to adapt if you have a crimping tool already. Alternatively if you are near Falmouth and can wait until the new year I will be down in January for dry dock for a few days and can lend/give you all you need. PM me if I can help. Soldering is not a bad idea too but I would use slightly larger heatshrink and smother the job in Sikaflex then shrink the heatshrink and allow the Sikaflex to go off, this will also ensure the job is waterproof. The blue crimp depicted is middle size, there is a smaller red and larger yellow available dependant on cable sizes. ![]() http://uk.rs-online.com/web/p/crimp-butt-s...s/4445665/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
the other option is something like this:
http://cpc.farnell.com/pro-power/stbht1/bu...tt=CN11433 Or just solder the joint and put some glue lined heat shrink over it. |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
Thanks Guys,
So, going back to my original post, to get a T splice I would have to cut the existing harness then, if using one of these connectors, put two wires in one end and one in the other? Would it be effective with 2 wires at one end of the connector? I read somewhere that crimped connectors aren't as good as soldering as they can corrode and add resistance to the circuit, so I take it that with the sealant in the heat shrink this seals it to prevent oxidisation of the joint? K9F thanks for your kind offers! Re your advice using heat shrink and sikaflex, are you suggesting sikaflex the joint then heat shrink over it all or sikaflex over the top of the heat shrink after it has been shrunk on? I think you are suggesting the former but wondered about letting the sikaflex cure after heat shrinking, wouldn't it be damaged by the heat ![]() Thanks again, Chris 2010 Defender 110 Station Wagon, Santorini Black. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I use these, all you need is a heat gun/torch,
http://www.ebay.co.uk/itm/10pcs-Heat-Shrin...5d4502c44f |
^^^ I used the same
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
Land Rover specify the ones like in Cupboard's CPC link for accessory fitting (spots/tow electrics).
That doesn't mean it's the best way though ![]() ![]() ![]() |
I always try not to cut the wire your joining too , which is ok if your near a plug or socket , I unpick the terminal out slide glue lined heat shrink over then refit terminal and strip insulting leave the oringnal wire in one length and wrap new wire round it then solder , so really your only joining two wires and not three makes a neater,smaller joint and you don't lose any length or strength of the original wires
I try not to use any type of crimp terminal , prefer to solder and bl@@dy hate the ratcheting crimp tool that all they do is crush the terminal on to the wires , most of the time you can just pull the wire out I always use the aircraft style crimper that folds the tails of the terminal into the wire so its a sort of m shape if you look in the end , funny some of the best crimpers I got are from a market and were a £1 a pair !!! I got maybe 15 pairs of crimpers collected up over the years from snap-on to market ones and the market ones work best , my snap-on ones I ground out jaws to make them better |
