Home > Puma (Tdci) > Another one with worn splines!!
Page 4 of 6 <123456>
Ian, your info is really helpful, thanks for posting! Thumbs Up
When I serviced mine I was pleasantly surprised at the cost of the parts, I was expecting them (esp the cup and shaft) to be much more expensive.
Did you have any trouble preventing the gearbox output shaft from rotating whilst undoing/doing up the rather tight nut that retains the cup to the output shaft? I ended up buying the special tool for this, whcih though pricey, compares favourably with the cost of the time needed to fabricate an equivalent and does make the job very sinple.
I agree with you that the opposed nipples (!) with a plugged hole in the case is the way to go. As I have a spare gearbox I might have a play about with it and design a mod.
Post #374556 27th Nov 2014 11:54am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Hi
I am glad i could help out on this, and you have found this post helpful!
To remove the large nut, i am fortunate enough to have a 3/4 air gun which will wizz off anything you put it on!
Dont forget a "dab of Loctite" on the threads!
I did not know the torque of the nut so i done it up to RED FACE TIGHT! Laughing (Trust me its not coming off!)
Having talked to the owner of the 90 today, he says it feels like a different car, much smother through the gears and no clunk when taking up drive, he was very happy.
So even though there was very little wear in the shaft, replacing and greasing really does make all the difference Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #374635 27th Nov 2014 6:54pm
Myo
South Africa 2010 Defender 90 Puma 2.4 CSW Stornoway Grey
ian series 1 wrote:
Hope this is of help to anyone?
Ian
Ian, is this an official bulletin from LR?
I'm on my second intermediate shaft, 2010 90, the last one went for 9000km Evil or Very Mad
Anyway, I just sent the dealer the reference number from your picture, will wait and see...
Myo
Post #415164 10th Apr 2015 8:45am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Ashcroft do an upgrade for this now also 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #415188 10th Apr 2015 1:05pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Just had my output shaft replaced on a MY2010 90XS with only 17500 miles on the clock, exactly the same with no lubrication on the splines. Shaft failed whilst driving on the M40 near Beaconsfield, suddenly lost all drive without warning even though engine was running and it was in gear, had to be recovered to JLR dealer. Upon removal of the transfer box dealer sent me a video showing the output shaft rusty and bone dry.
Vehicle has been repaired and JLR have offered a goodwill payment of 50% towards the cost as the vehicle is out of warranty. I would have thought that something like this would warrant a recall, surely it is a safety issue?
Anyway be warned if you have a 2010/2011 plate then this shaft WILL fail and is likely to leave you stranded without warning.
Post #415203 10th Apr 2015 2:33pm
ian series 1
Myo wrote:
Ian
Myo
Yes it was the info sheet my dealer gave me when I done the shaft on one at work Thumbs Up 80" 80" 86" 88" 90"
Post #415241 10th Apr 2015 7:32pm
Scoobeenut
That's the same parts list that the dealer has just given me on my invoice so it must be an official JLR bulletin.
Post #415249 10th Apr 2015 8:28pm
YOLO110
Australia
Just wondered if you can tell me if you know this issue has been solved on the later MY editions please?
Cheers,
Peter. Smile YOLO... You Only Live Once...
Post #415263 10th Apr 2015 9:53pm
munch90
Would be interesting to know if they have actually improved something , only 10 years late Rolling with laughter
basic engineering skills really !!
Post #415268 10th Apr 2015 10:07pm
Cheers,
Peter. Smile
Ask for an answer on the customer relations sub forum...
Post #415305 11th Apr 2015 8:21am
I don't think anything has changed, except that possibly they're lubricated better on assembly.
I have often wondered why vehicles built circa 2010 seem to be more susceptible to this failure than others.
Post #415319 11th Apr 2015 9:10am
munch90
^^^ lack of quality control as usual
Post #415321 11th Apr 2015 9:26am
BykerPete
United Kingdom 2014 Defender 110 300 Tdi CSW Willow Green
Post #415566 11th Apr 2015 10:31pm
martinfiattech
Most informative, thank you.
I plan to remove the transfer box next year to carry out the above work. I had a new shaft fitted, last year under warranty.
I wonder if you could fit a C.V. boot (cut to suit )
Around the splined shaft coupling to help keep the grease in and the dust and water out.
Has anyone tried this, I understand if you fitted this with, tie straps at 180 degree off sets the shaft would remain balanced Excuse the spelling I`am better with spanners and wires.
Post #415674 12th Apr 2015 1:31pm
Fatboy Slim
Wales
The ashcroft kit looks promising. Next time I do one I'll try and get one to trial out. Greasing will prolong the life a little but it's certainly not going to cure the problem.
Post #415739 12th Apr 2015 6:02pm
