Home > Puma (Tdci) > Recall
mse
Recall
Stratstone have called me today - apparently the oil pan (i assumed they mean the sump) is now a recall item.
Unless you guys know of any other oil related issue? Mike
Post #3742 10th Sep 2008 12:17pm
TJ101
Same here, had the call,,
Did ask why they wanted to it do again, when quite when the penny dropped that they had done it in April !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #3743 10th Sep 2008 1:09pm
Eduardo
Interesting,
According GTR there is not a new recall over the old ones. In the GTR still is a Service Action Bulletin.
That means a new pan change or is just for those with the original pan?
Here in Chile some friends of us also received a call from the dealer some days ago to change the original sump.
regards Eduardo
Post #3744 10th Sep 2008 1:48pm
mse
It seems anyone in the VIN range specified in the bulletin that HASNT had the modified pan changed is now due for it to be changed. Mike
Post #3746 10th Sep 2008 4:20pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Anyone know from what vin number?
Bosun
Post #3759 11th Sep 2008 7:10am
mse
There is a range: LD732615 - LD758400 however, apparently there are some either side of this so from 07 to early 08's Mike
Post #3776 11th Sep 2008 4:22pm
CapeLandy
South Africa
Is this pan of the new type or still old?
Mine is January 08
 Puma 110 - gone
Series III 1973 - going strong
Post #3789 11th Sep 2008 6:57pm
Eduardo
Old type,
There is a new one
Regards Eduardo
Post #3794 11th Sep 2008 7:53pm
CapeLandy
South Africa
Thanks Ed
Do you think they will change it at first service Question
If I were Landy I would rather change ASAP then replace seized engine Shocked
Weird that the dealer has had mine so many times and never sugested changing the sump.
Maybe here they don't know about it yet.
We are most times a year behind the civilised world.
James Puma 110 - gone
Post #3795 11th Sep 2008 8:47pm
mse
As above old type - mine was too Mike
Post #3796 11th Sep 2008 9:00pm
Eduardo
Your welcome James.
Will be a good idea call the dealer and talk about it with him.
It is not mandatory as I understand but looks like LR are trying to sort out the thing ASAP.
Here in Chile I know two persons that has changed the sump by guarantee without having damage.
Maybe you need to figth a little bit, but if you use the Defender in isolated areas the cost to recover the vehicle or burn the engine, as you said, will be much much expensive than change the piece.
My was changed in March after the propshaft hit the sump making a scratch (very lucky, I was at least 200 km from a populated area when we feel the hit)
Regards Eduardo
Post #3798 11th Sep 2008 9:21pm
mse
It would seem it is a mandatory at service change here in the uk.
That said the part is only �7 Mike
Post #3801 11th Sep 2008 10:09pm
Bosun
�7 to LR maybe, but to you and me probably ten times that! Oh, I forgot, plus VAT.
Post #3807 12th Sep 2008 7:07am
TJ101
From memory, about � 31 + vat,, The part number and correct price is on the "sump pan" thread somewhere California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #3809 12th Sep 2008 8:48am
DAZ110
I telephoned my local dealer today.
They told me the sump change is to be done at next service, or they were more than happy to book the landy in to have it changed next week under warranty. Thumbs Up I have decided to have done next week. Very Happy
DAZ110
Post #3819 12th Sep 2008 8:01pm
