Home > Puma (Tdci) > Another one with worn splines!!
Page 2 of 6 <123456>
Venomator
That's very good of you Ian, thank you... Bow down
Although, touch wood, I don't have any noticeable additional noises, yet... Whistle
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #374024 24th Nov 2014 10:03pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Also managed to get one of our work defenders cleaned off and ready for waxoyl tomorrow Whistle Laughing
I have found its the only way to get the mud from all the nooks and crannies!! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #374025 24th Nov 2014 10:04pm
munch90
munch90 wrote:
I took my t/box out to check after putting a camera in the casing and could see a small bit of brown dust , just greased it and refitted
I would say mine was quieter after , I would say more in 1st and 2nd going slow say in traffic jam
Post #374026 24th Nov 2014 10:05pm
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
You can stick a camera in there without dismantling anything??
Post #374066 25th Nov 2014 7:53am
ian series 1
How? The shaft is covered over with a black plastic collar held on with a cable tie, the only tell tale sign that it's dry is lots of red dust! 80" 80" 86" 88" 90"
Post #374069 25th Nov 2014 8:00am
munch90
no I drilled a small hole and used a bore camera and could see bit of brown/red dust on the black collar , you always get red/brown dust when any spline wears as they don't wear when they greased , get the same on drive flanges , props, car drive shafts that aren't tight enough , but at least you can see them !!!
not sure if drilling hole would weaken casing but only needed a very small hole for my bore camera ,
not something I would recommend anyone doing
Post #374073 25th Nov 2014 8:08am
fatman
I'll do the same,please advise me of the hole location(roughly) whenever you can...
Thanks.
Post #374074 25th Nov 2014 8:16am
dgardel
Italy
Re: Another one with worn splines!!
ian series 1 wrote:
Just thought i would post these pictures of the 2010, 90 that came into work today for the dreaded "rattly gear box problem"
Clutch springs were shot, and the splines on the shaft very dry and starting to wear.
It had covered just 31,000 miles! Big Cry
I do not think that the rattling problem is the splined coupling.
You can reuse yours adding MOS grease.
It does not seem irremediably damaged. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #374095 25th Nov 2014 9:42am
ickle
Ian,
Do you think it would be possible to drill a very small hole in the casing that would take a straw type oil applicator and spray some oil into the coupling without removal / disassembly?
If so whilst you have one of these out cold you measure where to drill?
Justa thought
Cheers Keith
Post #374096 25th Nov 2014 9:48am
dgardel
Italy
You need to grease INSIDE the splines.
If you spry the grease from outside, it does not reach well into the splines and when you drive the car the centrifugal rotation forces expels the grease from the shaft. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #374100 25th Nov 2014 10:12am
ickle
Danielle
I thought that the rotation and vibration would draw the oil down the splines, I saw something on cooling on a turbine once and the hollow center of the shaft help cool it?
Also if we could drop oil onto the top of the shaft at each service some would work its way in surely?
Keith
Post #374101 25th Nov 2014 10:27am
dgardel
Italy
Mhmmm the oil would be centrifuged before entering,
a grooved/splined joint needs high performance grease, the oil is not enough.
To be sure to do a good and definitive job you need to put grease in it. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #374102 25th Nov 2014 10:36am
When a mechanic friend of mine did one of these last week, he packed the outer piece with grease, then hammered the "shaft" piece in, so it's totally full of grease, splines an' all.
His idea for a modification, was to fit two grease nipples opposite each other, say at 12 and 6 o'clock. then drill a hole through the side of the extension case big enough to fit the head of a grease gun through (and tap it so you can fit a bolt afterwards) at least you could give it a pump of grease now and again.
Might be a pain getting it lined up with the nipple & hole though
Post #374104 25th Nov 2014 10:48am
ian series 1
J
Here are some photos of how the shaft has a plastic shield around it when fitted back together,
I can't see any way of inspecting, or lubricating them without physically taking them apart!
Drilling holes in the side and spraying in grease would not cure this IMHO
When it's all together again I will post a photo to show you can't see the splined coupling at all.
I'm fitting a new coupling just as a matter of course, as they have had one fail recently if it were mine I would grease and replace, but as it's a customer requesting this I will fit new parts. 80" 80" 86" 88" 90"
Post #374105 25th Nov 2014 10:51am
ian series 1
The idea of fitting a grease nipple to the side is actually a very good idea!
Why didn't land rover think of that??
With a little inspection plate to the side of the box. 80" 80" 86" 88" 90"
Post #374110 25th Nov 2014 11:03am
