Home > Maintenance & Modifications > Another Webasto Thread- but with a Tdi
Page 1 of 5 12345>
shaggydog
Hi guys
So, I have purchased a Webasto Thermotop z (not ideal, my own fault for not fully reading the label) for a very good price.
Once it turns up I will give it a go over and make sure It is complete and has all the bits as required.
I have had a look around and my 110 has this outlet on the tank.
Was this a clever bit of early Land Rover thinking to be an outlet for diesel heaters?
If so fantastic thats fuel pick up sorted! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #373712 23rd Nov 2014 1:35pm
shaggydog
Anybody have any ideas? Sad Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #373898 24th Nov 2014 12:42pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
I think that is a return point and as such does not have a long pickup or any pickup at all... 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #373970 24th Nov 2014 6:45pm
shaggydog
Poo thats annoying thought it was going to be a nice and easy install that way.
Though might be able to run a flexible pipe down it and into the tank perhaps? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #373974 24th Nov 2014 6:57pm
VeeTee
Netherlands
It may be possible to run a a fuel supply line through a special piece in the venting hose:
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #373996 24th Nov 2014 7:52pm
shaggydog
That looks like it might work Very Happy
Where did you find it? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #374005 24th Nov 2014 8:18pm
VeeTee
Netherlands
http://www.ersatzteilbox.com/product_info....-hose.html
I remembered reading about some installations using this kit, only don't know which forum or thread it was, was some time ago. But I think it may work well and seems no need to hassle with tank fittings or lifting the tank. Wink Cheers, Vincent
MySite
Post #374028 24th Nov 2014 9:19pm
shaggydog
There is this thread here http://www.defender2.net/forum/topic14809....sto+thread which is very handy and I have been taking very careful notes....
However Td5's have plastic tanks and much less room to fit them so I was hoping that this pipe would work.
Weirdly I have found no mention of this pipe which ether makes me think its a one off for my tank (highly unlikely) or nobody really knows what its for or what it does.
I'm a bit scared to unbolt it and see what it does because I don't want to break it and then have an open hole to my fuel tank right next to my rear tyre. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #374034 24th Nov 2014 9:29pm
VeeTee
Netherlands
Middle drawing, last row: Looks like your pipe. I don't know what it is for....
 Cheers, Vincent
MySite
Post #374046 24th Nov 2014 10:53pm
shaggydog
Yeah looks like it.
Do you think it would be anything to do with a dual tank set up?
Looks like parts 30/31 are some form of fuel pump, in which case the pickup idea may still work?
Need a camera on a stick to have a look inside! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #374050 24th Nov 2014 11:10pm
shaggydog
Success!
Just need to work out if its a pipe that terminates in fresh air which will be useless or if it goes to the bottom of the tank which hopefully it will! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #374052 24th Nov 2014 11:21pm
shaggydog
Majour leap forward in this little project when this turned up!
Also came with this wiring diagram.
Its a bit hard to see but looks like it just needs a live and neutral to the battery and then a signal live to fire up.
Seems simple enough Very Happy Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #374723 27th Nov 2014 10:14pm
Hazza
That outlet on your tank is almost certainly just a return with no pipe into the tank. I had my new (leaking) britpart one out from under the car yesterday and had a look 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #375266 30th Nov 2014 5:14pm
shaggydog
Thanks for the confirmation Hazza Thumbs Up
I have had a thought to make a gland which will screw into into the fitting with a thinner flexible pick-up pipe which will go down to the bottom of the tank. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #375267 30th Nov 2014 5:22pm
VeeTee
Netherlands
That is correct, but make sure you connect the live direct to the battery without a switch i.e. permanent live, because that is needed for the delay time of the fan after switching the heater off. Cheers, Vincent
MySite
Post #375268 30th Nov 2014 5:23pm
Page 1 of 5 12345>
