Home > Puma (Tdci) > ABS/TCS warning lights
Grockle
As above, I had our warning lights come on after the N/S/F wheel hit some wet leaves whilst decending a lane called The Pinch near to where we live, went to the local garage in Hartington where Ian managed to turn the lights off after a 'fault' with the pump was showing,all went well for some miles when they came on again whilst driving(not braking) this time the RAC came out and his 'box' said no faults but lights would not go out, the fault looked like being the pump(£2300.00)plus fitting, on collecting yesterday the reason for the warning lights was large fuse under the drivers seat which had blown total cost £80.00.
I thought I 'd tell you as the RAC man had no idea of this fuse and a 'main stealer' could have a field day with your bank balance. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #368442 31st Oct 2014 9:21am
jimbob7
Dont count your chickens yet,lol. FYI, £1400 inc vat from Br*tpart. Generic code readers aint very helpful on Defenders, Snap on Solus,etc,Either LR's own Testbook, Autologic or diy, Hawkeye,Nanocom or Lynx, I have Lynx. Pov.spec,ftw. 2006, 110,TD5.
Post #368460 31st Oct 2014 11:35am
Grockle
A bit more info ref Bulletin LTB00078v2 regarding warning lamps. 2.4 90 XS
Post #373946 24th Nov 2014 5:48pm
RED-DOT
Hi, can you guide me to the fuse please?
Thanks. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #374010 24th Nov 2014 9:23pm
Grockle
Good Morning RD,
Look under the drivers seat remove the secondary fuse bix lid, there are a line of heavy duty fuses, check through the clear cover on each fuse to see if one has blown. 2.4 90 XS
Post #374099 25th Nov 2014 10:11am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
there are other things that can cause this fault as well -I had the same problem with mine a while ago and it turned out to be an earth problem on the ECU - so had that re-earthed and all was fine at a cost of £20 ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #374162 25th Nov 2014 5:11pm
