Home > Puma (Tdci) > Heated Front Screen
Grockle
Heated Front Screen
Good Morning all,
RH side of the sreen wasn't working this morning, can someone tell me where to find the relay please.
Thanks 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #373860 24th Nov 2014 8:45am
munch90
think your find one relay for whole screen , so really cant see it can be a relay fault . sounds more like a connection problem or a break in the element wire in the screen
not something ive ever taken notice of , but sure you only have two connections for the screen one in each bottom corner , so if one side is working , I would say the problem will be the screen its self
Post #373861 24th Nov 2014 8:50am
Grockle
thanks for the quick reply mate. 2.4 90 XS
Post #373866 24th Nov 2014 9:28am
JWL
Unless........................there's 3 tabs off the screen Whistle My screen is split into two, the earth in the middle with power at each corner so just check first that you haven't got a flat ribbon wire coming out of the window rubber around the middle of the screen.
It all depends on who fitted the wiring as to where it all is as some fitters would interpret the fitting instructions differently, all will give the same result but may not follow a set pattern Whistle
If you have the three wire screen like mine then you'll just have to follow the wiring.
Post #373892 24th Nov 2014 1:04pm
munch90
mines standard from the factory xs it has 2 tags , passenger bottom corner purple wire , drivers side bottom corner black wire
if that's any help
guessing if yours is xs spec it should be the same ( you never know with land rover )
Post #373897 24th Nov 2014 1:27pm
Grockle
Hi Munch,
Two wires as you say,looks like it needs a new screen Sad
Thanks again. 2.4 90 XS
Post #373919 24th Nov 2014 3:22pm
K9F
A stone wiped out 50% of my last screen heater. Big Cry If you go through life with your head in the sand....all people will see is an ar5e!!
Post #373966 24th Nov 2014 7:41pm
Grockle
Mal if your drivers side is working I'll have it from you Wink . 2.4 90 XS
Post #374085 25th Nov 2014 9:13am
I am formulating a theory that the heated screens are perhaps not as strong as the non-heated. My original (non-heated) screen lasted 4 years and about 80k miles with only minor stone blemishes. In the 70k miles since I replaced it with the first heated screen, stone damage means that I am now needing my fourth heated screen. Big Cry
Perhaps stones that would make a tiny chip on an unheated screen cause irreparable damage to a heated one.
I accept that the shameful condition of the roads may be something to do with this, and I do do a high mileage (probably about 30k per year), but the number of screens I am getting through is ridiculous!
I always use genuine Pilkington, by the way (may be this is where I am going wrong)!
Post #374087 25th Nov 2014 9:21am
The heated windshield contains a single heating element which is powered for up to a maximum of 8 minutes when selected. The system is only operational when the engine is running.
Operation of the heated windshield is controlled by the heated windshield module. The heated windshield module is located behind the instrument cluster and receives an engine running signal from the engine control module (ECM). The heated windshield module also monitors the condition of the heated windshield switch. If the switch is pressed, a ground path is created. If both these signals are in place, the heated windshield module provides a feed to the heated windshield element until either:
1.the switch is pressed a second time
2. 8 minutes elapses
3. or the engine is stopped.
I had an issue last winter where the LH side of the screen didn't appear to work so dispite what the manual says it should be worth checking all connections to see if it's a temporary issue. Can't tell you what the issue was with mine as it was "fixed" by the dealer and when asked the service adviser didn't have a clue what they did.
The heated front screen relay is under the drivers seat and is the one second from the right in a bank of 5; the far right one is the relay for the timer. The underside of the seatbox lid may have a diagram to confirm this.
Post #374116 25th Nov 2014 12:09pm
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
Get a sledge hammer and smash it. Get you wife or daughter to go and see gavin at Autoglass and say that a 2cv she was following flicked a stone up at it! Like for like, job sorted! Lol
Wrong time of year not to have it working!
If you are not fully comp I wouldn't recommend this! Lol
Heated front screen and seats would be mandatory in Kevin's Britain.
Kev
Post #374413 26th Nov 2014 10:09pm
jimbob7
I'll have it if both sides don't work, as long as it's in good nick with minimal wiper marks, no chips or scratches etc. Wink heated windscreens are for toyota owners etc Whistle
The a55hole who owned mine last used his diamond ring to clear the condensation in a morning Neutral not to mention the wiper marks Sad Pov.spec,ftw. 2006, 110,TD5.
Post #374422 26th Nov 2014 10:48pm
K9F
Rolling with laughter
Ironically enough it was the driver's side that still worked. Will chop it in half tomorrow to reduce the postage. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #374446 26th Nov 2014 11:43pm
MOve
England 2015 Defender 110 Puma 2.2 CSW Keswick Green
Black wolf wrote:
"I am formulating a theory that the heated screens are perhaps not as strong as the non-heated. My original (non-heated) screen lasted 4 years and about 80k miles with only minor stone blemishes. In the 70k miles since I replaced it with the first heated screen, stone damage means that I am now needing my fourth heated screen. Big Cry"
Had a Mondeo for 3 years, heated screen, 50,000m, never failed or replaced. Had a Range Rover Vogue for 3 years, same miles, no problem. Country lanes in East Mids and East Anglian and main roads and motorways.
Maybe just bad luck! Sad
Post #383827 1st Jan 2015 10:32am
