Home > Td5 > More clutch/gearbox parts purchased.
excossack
I think I have all the bits for the man to do the clutch/gearbox swap for me apart from g/box and TC oil.
Yesterday I purchased;
FRC3416 - Retaining clip - by the looks of the diagram I found online, it attaches to the release bearing
FRC5255 - Clutch frition pad
The friction pad by the looks of the diagram goes on the end of the arm in the gearbox bell housing. Is this just to allow smoother clutch engagement, or for the release bearing to spin when the clutch arm is pushed up against it? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #373575 22nd Nov 2014 10:27pm
silky16v
England 2001 Defender 90 Td5 X-Tech LE Blenheim Silver
TD5 don't use the friction pads
Post #373644 23rd Nov 2014 9:55am
munch90
Re: More clutch/gearbox parts purchased.
the only thing you need to watch if your supplying your own parts for a garage to fit is if anything goes wrong with those parts you will need to pay them again to fix it then try to get money back for the extra work from your parts supplier and that's never easy , if the garage supply and fit there own parts and something goes wrong its then down to them to sort it out .
we get a lot of people do it and love it because it takes the warrenty on the parts away from us and on to the owner all we need to do is warrant how we fit it not the parts
I know some people do it to save money etc or so they think there getting better parts , but not always the case and can be false ecomony
just say you want genuine parts it wont be a problem for most garages ( ok they might cost you a bit more )
just an example , other day merc comes in for service , car is 6-7 years old , customer supply there own genuine parts said it cost him about £140 , we had already ordered a service kit for it , opened the merc parts all marked mann and exactly the same as our mann parts , but ours would have been £100 cheaper
I know this is not the case with all garages , there is good and bad in every trade
Post #373651 23rd Nov 2014 10:40am
excossack
Cheers for the replies. In that case I will send the friction pads back.
As for parts wise I have supplied
Clutch kit - Valeo
Gearbox - ashcrofts
Gearbox - release bearing clip
Transfer case - Disco one
Hand brake drum shoes - DefenderBits
Transfer case gasket set.
So....pretty much most of it!
Fingers crossed it all goes well. The mech doing it is a friend of a friend, who has been doing his Landy for a while. 1999 Defender TD5 110
Regards
John M0VAZ
Post #373752 23rd Nov 2014 6:14pm
