![]() | Home > Technical > Rough idle when cold |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824 ![]() ![]() ![]() |
Andrew mine does the same . Very rough when started from cold but once it warms up sounds fine again. I find if I dont use too much throttle for initial 5 mins or so the coarse rattle is not so obvious. Have noticed it is getting progressively worse, so will have to get booked in to the dealers again !!!
Well mine is going in tomorrow for the following issues
Rear prop to transfer box bolts keep coming loose Rough idle when cold New sump Clunky back lash type noise in transfer box Water running down the carpet each side of the transmission tunnel (I suspect a blocked drain in the heater/AC) Chatter from gearbox when under load |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Have you been driving my 110??? ![]() ![]() Tim |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Andrew
I have a list of 13 items that has been repaired or are under repair now that includes much of them. In fact, the car have visiting the dealer at least 1 per month (now is there!) ![]() But still I love it ... keep me busy ![]() Maybe will be a good idea to keep an statistic of the failures to be aware. Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge Last edited by Eduardo on 9th Sep 2008 7:45pm. Edited 1 time in total |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8360 ![]() ![]() ![]() |
Andrew so is that to do with the latest engine replacement solution for here?
http://www.defender2.net/forum/topic472.html Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
I will find out today
sib Member Since: 18 May 2007 Location: Baaath Posts: 144 ![]() |
Hi Andrew S
Would be very intereted to hear what your dealership thinks the "transmission chatter under load" is as I have that with my 130. They`ve looked and done something to clutch but still same problem, so much be gearbox/propshaft related.. sib Sib Bath UK 1952 80 inch 1973 88 inch 2018 Morgan plus 4 narrow body |
Andrew any news on your Defender yet ?
Mine is at the dealers now and I have been told it needs a complete new engine ![]() Wont see it for a couple of weeks. Very inconvenient ! What concerns me now is how much experience does my local dealer have of installing a new Puma engine !! Hope you have better luck with yours. N. |
Sib it was the rear prop bolts again
![]() Nidge Got the car back now and have been told to monitor it ![]() |
Should change the title to rough idle whenever, anyway changed dealer. The new dealer has found that the up dated software was saying it had loaded but actually hadn't, it took 4 goes to finally get the software load. They then carried out a re-learn of the pump and injectors. Finally after over 12 months the car idles like a puring pussy as opposed to a rattlesnake on crack. 130's have feeling's as well you know
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 ![]() ![]() ![]() |
Same problem here. Main dealer/vehicle supplier failed to update injector software correctly, took it to another main dealer who identified the fault and updated the software correctly. Some dealers here seem to have issues with their computer systems and this is causing some problems.
Spent the morning driving the car, WOW its like new a dream to drive
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
I've been told today of another car that didn't have the pilot correction set and drove badly. This car had only 5 miles on it and was direct from the factory
![]() After it was done which in the end was a full download and update all was fine. It just does go to show even the factory are having problems. Pete |
