![]() | Home > Td5 > Recommended road springs for a TD5 90 |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
load it up
silky16v Member Since: 11 Aug 2014 Location: Cumbria Posts: 99 ![]() ![]() ![]() |
Lol already has Patriot roof rack
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
Rangerover classic or disco1 V8 springs would be quite soft i'd imagine.
anyone else needs some options?
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
I have defender 90 front springs fitted to the rear as well. This gives a lovely smooth ride but without loosinf the load carrying capability. I have them teamed up with Terrafirma dampers and I am really pleased with it. So much better than the standard set up.
I wa recommende to also replace the fronts with Range Rover springs, but I have not done so as I feel like I have it just right. I was advised to do all this by a JLR Engineer who works at Gaydon - so it is 'official' advice. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
Check out Alive Tuning. They have just what you're after which will go well with your Bilsteins & road use,...Alive have springs that will level up the ride height of a 90 & lower it about 1-1.5".
Pickles. |
yeah looked at Alive but the price isn't justifiable just for the springs
H3nry Member Since: 08 Jan 2014 Location: Heathrow Posts: 134 ![]() ![]() |
@Alex:
Which year of Range Rover spring is recommended by JLR? Only the front, what about rear? |
I will need to check the advice on the Range Rover springs for the front as I kept to the standard Defender 90 CSW springs, the rears are the same as the springs I have on the front.
does your landy now not sit arse heavy having fitted the front springs on the rear?
NigelM Member Since: 20 Nov 2014 Location: South Posts: 114 ![]() ![]() |
4304'2 on the front and 4305's on the back. the 4305's are the red/white RR Police springs rated at 170lb's (opposed to 225 std) and the fronts are 150Lb's. Give about an inch of lift but make a significant improvement to comfort. I put them on mine a couple of months ago, very pleased with them. Combined with Koni shocks it now almost qualifies as comfortable.
In terms of load carrying, when I put 120kg of wheat in the back it drops about 1 1/2" and looks a little tail heavy, but that's only a couple of times a week and the rest of the time I run pretty light. |
