Home > Maintenance & Modifications > Engine replacement
Mack
2008 Defender 130 Puma 2.4 HCPU Chawton White
Engine replacement
Hi mates. Just thinking ahead and wondering if anybody has experience with these engines http://www.nav-international.com.br/site.aspx/Vehicular
They look quite appealing to me, specially the 4.3H being mechanical (the only thing is its almost twice as heavy as the puma engine) but they have options that weigh the same.
Transmission-wise can it be possible?
Mack
Post #372930 20th Nov 2014 5:08am
Stue5
Italy 2005 Defender 110 Td5 USW Alpine White
Earlier this year I saw a 90 getting fitted with a Cummins 6BT Shocked the plan was for the truck engine and gearbox to be installed as one and mated at the transfer box. The engine is found in quite a lot of 7.5t truck over here. Lots of tuning bits in the US. There are a few 6bt defenders on YouTube. Here is a photo of Aaron's 90( taken from his posts)
http://s66.photobucket.com/user/aaronmorri...5.jpg.html Range Rover p38 4.6 99 lpg(gone Sad )
Post #372936 20th Nov 2014 7:00am
Mack
Wow that Cummins looks great in there. I was thinking of the International engines as they have a good name in reliability and performance and I can get them at a great bargain from their Brazilian plant. What about the engine weight? That Cummins must be pretty heavy compared to the Puma as I believe the Puma weighs around 200 kg dry. I suppose the extra weight might affect off road performance? I like the International 4.3H as it does not have an ECU and has plenty of power, is a 4 cyl BUT weighs around 450kg. Im just thinking ahead as I want to keep my Defender until I die and Im not really an enthusiast of the Puma engine for when mine needs replacement (I hope for many years from now). Just wondering how would ine adapt transmission etc. Ive been saving some pennies every montg since I bought my Defender for when that day comes.
Mack
Post #373088 20th Nov 2014 7:28pm
Stue5
Here is Aaron's build thread = http://www.landyzone.co.uk/lz/f7/aarons-90...47956.html
I think some toyota's had a 4BT cummins(may be wrong), here is a Australian mod defender with the 4bt cummins (even though it says Isuzu)= http://www.milweb.net/webvert/73010
Hope you get some other ideas thrown your way Thumbs Up Range Rover p38 4.6 99 lpg(gone Sad )
Post #373100 20th Nov 2014 8:03pm
Mack
That Cummins 4BT got my attention, taking in mind the job has already been done! I like its mechanical (no ECU) and I can also get Cummins here (a little more expensive than International). I believed the 3.9 was an Isuzu engine, until today.
Which one would you go for Stu?
Mack
Post #373110 20th Nov 2014 8:28pm
Mack
Noticed on tthe thread they said tje strongest gearbox fitted on a Defender was the LT. I thought it was the six speed on the Puma, considering it is used on many other vehicles with lots more power. How much can the 6 speed take?
Mack
Post #373113 20th Nov 2014 8:39pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Officially around 500nm they fit that gearbox to the mustang whitch producers 5-600hp but it's torque that breaks them as I have found out 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #373149 20th Nov 2014 10:03pm
shaggydog
Ohh thats a dangerous page to look at. Lots of grunt available.
If you do go ahead with the swap please put some photos up! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #373169 20th Nov 2014 11:17pm
Mack
500 nm sounds pretty good to me. 450nm would make me more than happy! If the 360nm (according to LR) in the Puma does the job, 450nm should be impressive!
Post #373198 21st Nov 2014 8:09am
Mack
Thats right shaggydog, it makes one want to go crazy! Its not something Im planning in the near future Im just doing some research for when my Puma dies and needs replacement and those Inter engines blow my mind Twisted Evil
Mack
Post #373199 21st Nov 2014 8:13am
big steve
get it remapped then and you will know what 450 is like simples and far cheaper than any engine conversion
steve 2015 2.2 tdci hardtop xs
Post #373211 21st Nov 2014 9:30am
Stue5
If I could have a 6bt in my 110 I would, but that is only a pipe dream for me Big Cry . But it is not impossible and fitting it into a 90 shows that brilliantly. I will have to be happy(which I am Thumbs Up ) with my 5 cylinders. Range Rover p38 4.6 99 lpg(gone Sad )
Post #373578 22nd Nov 2014 10:29pm
Mack
Steve with such mods, will the engine see its lifespan considerably reduced ?
To source a Puma here is overpriced (in my opinion 12k usd is an abuse), so I was thinking for when my Puma eventually dies I would replace it with an engine with a little more displacement so it would be under stressed and last longer.
Mack
Post #374852 28th Nov 2014 4:36pm
Mack
Stue a 6bt would be living a dream, I was also considering the 4bt (taking in mind engine weight) as it has already been done many times (so I was told in the thread). Cummins still manufactures them for non highway applications so getting parts for a rebuild on a road engine should be easy. Also those International from the link I posted will do pretty good. Probably they would be expensive to take to the UE, just as it is expensive to bring the Puma here.
Mack
Post #374854 28th Nov 2014 4:41pm
Mack
*you mentioned the 4bt Stue, my apologies!
Post #374855 28th Nov 2014 4:45pm
