Home > Off Topic > Best adhesive for rubber to stainless.
leeds
As title says what is best adhesive to adhere a rubber mat to stainless steel?
Not after an ultra strong structural bond. Just need to keep a rubber mat in place.
Any ideas folks.
Brendan
Post #372411 18th Nov 2014 10:01am
Black Tac (Used in the Photo industry) Thumbs Up
Post #372413 18th Nov 2014 10:03am
Martin
Site Admin
Also comes in blue I've heard Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #372440 18th Nov 2014 11:40am
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
Good old Eco-stik
Post #372448 18th Nov 2014 12:15pm
Totally different (No not just caus its Blick)
Post #372453 18th Nov 2014 12:44pm
Blacktt600
Or this, it sets in water as well
Post #372454 18th Nov 2014 12:58pm
gilarion
Depends what you mean by rubber, if the rubber contains Urethane then it will not stick to stainless steel, nor will any rubber that during its curing process oil has been used or oils as a release agent to take it from the mould or roller, as the rubber molecules will absorb the oil, you may find initially that the rubber will stick but over a short time the oil will bleed and destroy the bond. You would have more success if the rubber is synthetic.
Also be careful if using solvent-based glue as some solvents will over a short time melt the rubber destroying the bond. In any case you will need to key the surface of the stainless steel particularly if it is highly polished. Ideally you would need a cyanoacrylate adhesive but that may be impractical.
If the rubber you intend to stick will have little load i.e. not a strip of rubber that you intend to stick on say a stainless steel side bar or step then a common tube or tub of non-solvent based Evo Stick will suffice and should give a reasonably strong long lasting bond. If the rubber is to be used in a load area you will need an adhesive such as Master Bond which you should be able to source from any good quality builders merchants.
Post #372459 18th Nov 2014 1:09pm
