![]() | Home > Maintenance & Modifications > Performance brake discs |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
I would like to improve the braking on my 110 and I'm looking for some performance brake discs + pads.
I don't like the common "performance discs" that everybody sell (Terrafirma, Bearmach,Britpart etc...):the grooves are very few and shallow, while the holes, in my opinion, are unnecessary and can cause cracks or failure in case of strong stress. I've found on the bay those discs, the 20 groove is the one I'm looking for, does someone knows this company or has any other suggestion? ![]() Defender 110 Td4 SE MY 09 |
Wich MY is your 300??
Because only the last production has front vented disc, otherwise there is a big difference between standard vented and non-vented disc... The 110 from 1999 has front vented disc, wich improved the braking performance, but power of braking is still ridiculous... ![]() Defender 110 Td4 SE MY 09 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2475 ![]() ![]() ![]() |
I agree, braking power is lousy. I wonder why a similar size truck (any jap-chinese-korean) has better performance. Puma 110" SW
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20870 ![]() ![]() |
Weight ![]() |
Better this one kit Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
I don't think so.... ![]() There have been a couple of occassions due to 'my style' of driving that I have had to stamp on the brakes pretty hard, both times I could not have expected them to perform any better. Why is it you feel the need to upgrade? Just a query from an interested individual. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Those are drilled....not the ones I'm looking for... I've received a quotation from Nitrac and a full set of performance Cryogenically treated 16 groove discs for Defender cost £366 includes VAT and shipping. I'm also waiting a quotation for Tarox g88 Matteo Defender 110 Td4 SE MY 09 |
I use my Def quite often on motorway and mountain, and in both cases I've found lack of power braking, either for speed in the first case or the powder in the second. Changing only brakes pads I'll not solve the problem. Matteo Defender 110 Td4 SE MY 09 |
It's not the braking power but more the controll off the braking power and tyres;
&feature=player_embedded#! Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 ![]() ![]() |
They're only about 2-tonnes. Freelander is approx 1.7 tonnes and brakes far better. Navara is 2.2 tonnes and even with rear drums brakes a bit better. Then again with all the bling people seem to hang off Defenders they're probably closer to 3-4 tonnes ![]() |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 ![]() ![]() ![]() |
what about the dba 4000 series....
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6670 ![]() ![]() ![]() |
Take a look at www.motorsportworld.co.uk - they might be better priced as they have a reasonable discount ![]() ![]() ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5103 ![]() ![]() ![]() |
My 90 mainly does motorways and country lanes at national speed and i have to say the brakes and action is perfect - couldnt ask for more - better than the other cars...but not the RRS when i have it Within the first 7 days - country lane (wide) traveling at 60 tractor pulls out (classic image) brake and swerve - brakes perfect. Mike |
mse mine is a 110, different weight and different reaction in case of braking, but believe me, the OEM brake are not perfect at all.... Matteo
