![]() | Home > Puma (Tdci) > Where is this nut from? |
| Alicat Member Since: 25 Nov 2013 Location: Hertfordshire Posts: 143
I had a rattle in the rear of the 90. On further investigation this nut fell out. It came from the bottom of the trim that surrounds the rear side windows.
Click image to enlarge Any idea as to what it should be holding together? Thanks Tony |
| smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233
It looks like one of the nuts that hold the side panels onto the tub. When I took all the trim off mine I found that half the bolts didn't have nuts on and two had loose nuts. It was quite worrying to have found the only thing keeping the body on mine was probably the weight of the roofrack
Hmmmm, I suspected it might be something like that!
I won't started taking the trim off yet to check the others. Thanks Tony |
| Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3802
Had the exact same nut, found in exactly the same place, & I put a post up about it.
Dealer had a look, put some sort of torch/mirror along the inside of that plastic trim & said everything looked ok. I've had no more rattles, nothing is vibrating or appears to be loose etc, so I'm not too concerned. Others have had similar items found in various locations around their Defender! Pickles. |
| richardg Member Since: 17 Dec 2012 Location: Cumbria Posts: 30
Found the same nut when took off the rubber cap where the old style jack used to fit on the chassis at the front end.
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2279
Here is the very nut fallen from its home behind the plastic window surround panel . It's not from the panel but from the body capping from the tub to hardtop . Only solution is to locktight it on as it always comes off , there are more of them .
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
It is, as others have said, from the bolt that secures the side panels to the tub.
One of these on my demonstrator dropped off as I pulled away from the supplying dealer on the day I collected it We often find them loose when removing the trim to leather. |
Cheers Keith, that is exactly where mine dropped out from.
Tony |
