Home > Td5 > Intercooler fan
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Intercooler fan
2000 110 Td5. Had it for a couple months now, and previous owner mounted an electric fan infront of the intercooler.
I think it's overcooling the rad, as it's not running up to operating temp. Our weather is right around freezing last couple days, and I think I'm about to disconnect it.
Anyone have any info on this set up? Is it worth keeping?
Post #371727 15th Nov 2014 5:56am
If it's got ac then I might be the aircon fan - standard electric fan in front of aircon rad / intercooler / rad
Do you have a picture ?
Are you experiencing this with the ac off ?
Post #371729 15th Nov 2014 8:05am
CDN38
Yes, it's got A/C. The fan stays on at all times, even with A/C off.
I'll post a picture once I get a chance
Post #371780 15th Nov 2014 3:06pm
landy andy
Sounds more like you've got an AC problem and that is causing fan to continually run.
Pull the AC fuse and see if it stops.
Andy
Post #371787 15th Nov 2014 3:55pm
CDN38
So it defiantly shouldn't be running with the A/C off? Hmm must be a sensor or switch issue.
Post #371788 15th Nov 2014 3:59pm
landy andy
No. Although I believe if the engine temp is very high the ECU can activate the fan to assist with cooling, but normally only on when AC switched on.
Post #371789 15th Nov 2014 4:11pm
CDN38
Hard to think of the engine ever getting hot... Gets warm, but hot is on the wish list.
I'll try pulling the A/C fuse and see what we get.
Post #371791 15th Nov 2014 4:17pm
Fatboy Slim
Wales
You'll find you have a logged fault for a temperature sensor. Clear it and all will return to normal Thumbs Up
Post #371825 15th Nov 2014 6:47pm
Lorryman100
landyandy is spot on about the AC fan running as part of the EMS overheating strategy on Defenders fitted with A/C. Have you carried out any diagnostic checks? I would be curious to know what the readings/live data are from the CHT sensor?
Post #371843 15th Nov 2014 7:47pm
CDN38
Going to take it in on Monday and plug it in.
Post #371844 15th Nov 2014 7:49pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I believe the A/C fan should normally cut in when the ambient temperature is above 28 degrees C ( not very often in the uk). I hope someone hasn't wired the fan to run continuously to disguise an engine temperature issue ! 2005 Td5 90 XS
Steve
Post #371852 15th Nov 2014 8:14pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
A/C fan si controled by the TD5 engine ECU. I was written here - check engine ECU for faults. When TD5 engine goes over temperature it started the A/C fan and will start it again every time engine is running.
With Nanocom you can also test the fan - it can energize it for a short time. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #371853 15th Nov 2014 8:28pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
An overheating fault or a faulty sensor will cause the A/C Dan to run constantly. Clear the fault and/or replace the sensor should cure the issue. It wasn't me!
Post #372347 17th Nov 2014 11:34pm
Fatboy Slim
Wales
I've had this happen several times in the past with flat batteries or a jump start causing the temp sensor fault. Clear it and all returns to normal
Post #372538 18th Nov 2014 8:18pm
