Home > Td5 > Td5 Cylinder Head
adseybear
Canada
Td5 Cylinder Head
Just had this delivered as a supposed brand new AMC cylinder head.
Could someone confirm I should be rejecting this...
He's argued with me that its fine and even sent me a pic of another one from the same supplier with the same supposed machining hole.
 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #371493 13th Nov 2014 8:12pm
excossack
Which hole is that ? and is there another dent on the 2nd picture, above the triangle bolt flange?
or maybe worth asking say Turner Engineering? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #371498 13th Nov 2014 8:23pm
adseybear
Canada
Its where the rear of the camshaft would sit.
Interestingly I've just found this picture online which also seems to show this machining hole
However yes, I've emailed AMC and Turners with pictures and asked their opinion. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #371501 13th Nov 2014 8:32pm
Fatboy Slim
Wales
All looks fine to me, the hole is to allow oil to drain away from the cam otherwise it would just pop the rear cam seal out
Post #371502 13th Nov 2014 8:35pm
adseybear
Canada
just had a reply of Turners
Dear Adam
Thank you for your e mail and attached photographs.
The cylinder head is exactly the same as the last 1000+ AMC cylinder heads we have sold. The red circle shows an oil return hole, pressure would build up without it. The ball bearings seal the fuel gallery and are peened into place. There appear to be one or two minor dings and dongs on the head that will not affect fit, function or purpose. The slight damage has most likely been acquired after unpacking. AMC heads are extremely diligently inspected prior to packing at the factory. Has the AMC packaging been opened/changed prior to delivery?
Certainly put my mind to rest a bit! 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #371511 13th Nov 2014 9:15pm
NickMc
Yep all standard.
Post #371549 14th Nov 2014 12:20am
