![]() | Home > Maintenance & Modifications > Leaking window seals-can you still buy liquid silicon sealer |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Can try this http://www.ebay.co.uk/itm/CAPTAIN-TOLLEYS-...0568235437
Worked for me on sealing my roof ![]() Just make sure you wipe off any excess because it will leave like a PVA glue type varnish mess if you don't wipe it off immediately. Also make sure you do it on a warm dry day or in a workshop where it can creep in and dry, rather than get washed out again. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
dlks151 Member Since: 30 Jun 2014 Location: Auchinloch Posts: 67 ![]() ![]() |
You could try some of the Techsil RTV product range, its a very viscous product which we use for potting leds for use underwater.
http://www.techsil.co.uk/catalogsearch/adv...mp;search= |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135 ![]() ![]() ![]() |
For anyone trying to cure leaks or in Land Rover terms 'water ingress' this is the stuff to use. I believe it is the same product Land Rover use themselves at least in their water ingress manual it recommends this product.
look here for lionks http://www.defender2.net/forum/topic32417.html |
Captain Tolley's in Saggydog's link is one of the best. If the cracks are large Captain Tolley's first then seal up with Sikaflex 29i afterwards.
![]() Treat every day as if it is your last....one day you will be right!! |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 ![]() ![]() ![]() |
K9F..... where do you get Sikaflex 29i from please? or is it the same as Sikaflex 291i?
Thanx in advance |
Missed the '1' out sorry.
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Thanx...
![]() At least I'm not going (too) mad ![]() |
