Home > Puma (Tdci) > 130 Front springs on a standard 110 puma
pannawonica
Australia
Has anyone done the above, and what are your impressions on the mod! Very Happy
Post #370265 8th Nov 2014 4:24am
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
Hi
I fitted the HD springs to the front of mine.
I find it improved the handling, but there again the old springs were tired.
http://www.defender2.net/forum/topic25618.html
Post #370271 8th Nov 2014 6:44am
pannawonica
Australia
Mine have done 67Km's, however I done have a fullARB bull bar. It kind of falls into corners. Very Happy
Post #370285 8th Nov 2014 8:56am
I used to have a BRB bar (similar to the ARB bar) with an 8274 on my Td5 110.
I fitted HD front springs (110 HD = 130 standard fronts) and although the ride was bang on, i found it was a little front nose-up (think it might be the rear end "down" on mine giving the impression of a high front end)
But it's a good cheap mod for a heavy front end. like you, i found that with the weight of the bar and all the rest of it, the front would crash at the slightest pothole.
I did try HD fronts on my old 110 that was totally standard, nothing on the front.... waaay high and handling was horrible, understeer everywhere as there was no give in the suspension.
Post #370316 8th Nov 2014 11:56am
roel
What springrate do they have? I changed my 90's from 175 lbs/inch (standard front) to 225 lbs/inch (standard rear) that's about right for me I think on the moment with a homemade winchbumper with warn winch. Roel
2003 90 Td5 (2009-now)
Post #370346 8th Nov 2014 4:27pm
A 90 HD front is a 90 standard rear.
Post #370424 8th Nov 2014 8:59pm
AndrewS
I think the front springs on a 130 are the same as a 110. I have a spare 130 set kinking about the workshop I will measure them up and take the colour code and let you know.
Post #370499 9th Nov 2014 9:33am
110 heavy duty and all 130 (3500Kg)
Front - Driver's side NRC 9448 Blue/red
Front - Passenger side NRC 9449 Yellow/white
same springs used also for:
90 2 seat utility (2400 Kg)
Rear - Driver's side NRC 9448 Blue/red
Rear - Passenger side NRC 9449 Yellow/white
Post #370540 9th Nov 2014 12:25pm
Tom The Locksmith
England 2012 Defender 110 Puma 2.2 USW Java Black
Springs
I had my 2012 defender utility back into LR after fitting a winch bumber and winch & under body protection to my landy.
They fitted the heavy duty ones they use on the 130.
Front ones were replaced for new springs & the rear ones had additional springs fitted inside the originals.
I can't remember the part number but they were genuine parts and lifted the vehicle slightly & can now carry plenty of kit without worrying.
Handles nice and firm too.
Post #370866 10th Nov 2014 8:15pm
The only difference should have been the addition of the helper springs. Base rear springs are the same for yours and 110 hd/130:
Rear - Both sides RKB101111 Purple/brown
Rear helper springs - Both sides RRC 3266 No colour code
Post #370953 10th Nov 2014 11:58pm
