Home > Maintenance & Modifications > Remap / Tuning
Wheel
Remap / Tuning
Hi Everyone,
Does anyone know if there is an officially approved, as in it won't invalidate the warranty, a Co that does tuning and/or remaps ?
I don't know if B.A.S. / Alive / Twisted to name but a few are approved or not, does anyone ??
Thanks,
Mark
Post #370114 7th Nov 2014 2:29pm
K9F
Short answer.....No there isn't one!
Unless of course you buy a Bowler, Twisted or some other version mapped and tweaked that they themselves would honour the warranty.
You either 'bite the bullet' and go for it or wait I'm afraid. Choice is down to you and of course your relationship with your dealer. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #370125 7th Nov 2014 2:54pm
As Mal (K9F) mentions above..
I have an Alive map on mine from Gary, very pleased indeed with it.
I personally if I was you wait for it to come out of warranty.
After that get it done, on top of the improvements to performance etc you can get shot of the EGR which WILL cost you money and issues once out of earrenty anyway.
These alone are £140 each exc fitting providing you do it yourself which is a PITA I can tell you.
The Alive ATRIC tuning device alows you to run between the standard map and your remap I.e. You can load either when required.
You'll get an EGR blank too if for a Puma.
The ATRIC device also will show you DTC's (fault codes) and allow you to clear them if fixed at home.
Thumbs Up
Post #370182 7th Nov 2014 7:27pm
Alive Tuning
Having a remap does not simply invalidate your warranty!
The problems occur when, for example, a component within the power/drive train fails, as a result of excess torque being transmitted through it. This includes items such as the clutch and flywheel, gearbox, transfer box, prop shafts, differentials, half shafts and drive flanges. Another example is failure to to excess heat, such as a manifold face warping. In the event of a failure, you would have to pay for the repair, parts and labour, simple as that.
You should be up front with your dealers, disclosing any non standard modifications to them, so they understand how they can best deal with your problem. If the dealers were to return a failed component to JLR for a warranty claim, which they do, they could tell if the component was over stressed and could easily refuse the claim, leaving the dealer out of pocket, and the cars owner in bother, with the potential of fraud charges!
Any reputable tuning company will not do anything to damage a customers car, as it's no good for their reputation. A specialist tuner will understand how the vehicle works, where its limitations are, and how much they can safely wring out of the engine without causing problems. Take comfort in the fact we know our trade, and our reputations are a reflection of this knowledge and experience.
On the flip side of this, parts for Defenders are pretty reasonable, so if you do break a half shaft or drive flange, it's not going to be an expensive fix.
Regards,
Gary.
Post #370204 7th Nov 2014 8:17pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I believe bowlers map is approved and warranted by landrover but then you need a 2.2
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #370222 7th Nov 2014 9:56pm
Alive Tuning
Is that actually the case Steve? I expect they most likely have some kind of insurance cover instead.
I know it's big money, but then I've heard you get an additional ECU as well?
I'll happily stand corrected on this one, as I'm not aware of it.
Post #370227 7th Nov 2014 10:09pm
ericvv
Not so sure, I had this year two half shafts replaced by my dealer, nothing to do with stress from a map which I do not have, but replaced just because there was some play in them. Luckily still covered under the LR extended warranty, but I saw the dealer invoice for the parts and work which they sent to LR warranty, and that added up to the equivalent of a healthy £1.200,00... I believe that 2/3 of that was for the parts.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #370233 7th Nov 2014 10:29pm
I had a clutch bill and some other things of nearly £1500 this year, repair prices are getting ridiculous.
Anything much more and I'd be forced just to leave it on the drive seeing as it comes out of our pocket.
Warrrenty you can't keep forever.
Having said this I contemplated selling up at one point but realised that other vehicles still cost more or less the same but you get less in return from the vehicle.
Post #370234 7th Nov 2014 10:33pm
Forgot to mention also that quality of parts etc does not always come into it.
Just because you have it mapped does not mean you have to drive it like a racing car and put it through in-due stress.
I think it's good to have the extra power there when you need it but other than that not race it.
After all, extra power is nice but doesn't meant to say you have to drive around using it all the time.
Post #370235 7th Nov 2014 10:37pm
big steve
I was told that somebody with a set of bowler wheels need a new diff and supposedly landrover refused because they were modified with different wheels but had to do it as they were a dealer fit was nothing to do with the wheels
Gary I could well be wrong as I don't know but either landrover are doing it or bowler are covering it ?
As you say an insurance would cover it
Post #370236 7th Nov 2014 10:39pm
bell-auto-services
Re: Remap / Tuning
Wheel wrote:
Hi Everyone,
Thanks,
Mark
Hi make, What model car and engine do you have ?
Post #370252 7th Nov 2014 11:58pm
K9F
Pete.....
My guess would be none yet but it'll be a 2.2 unless he got a cancelled order, or a stock one.....
From September...
Wheel wrote:
........I'm about to order a new SW 90 XS .........
Post #370253 8th Nov 2014 12:12am
Wheel
Yes, none yet but getting a new 90 XS due in Dec
Post #370303 8th Nov 2014 10:12am
K9F
With your historical experience of owning two Defenders before you may be pleasantly surprised at the capability of the 2.2? Yes there are 'quirks' with the much publicised 'rev hang' (do a search) but even a remap does very little (if anything at all) to cure that. Other people find no issues at all. I remapped mine (2.4) before end of warranty and the 'relationship' between me and my dealer at the time was basically that he wasn't really that bothered. I did have warranty work still carried out but it was cosmetic only and had nowt to do with 'running gear.' It may well have been a different scenario had it been clutch, gearbox etc. related issues.
I wouldn't rush into anything performance related until you gauge the characteristics of your new purchase. If it gets built on a Friday forget everything you'll be a very busy chappie.
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #370304 8th Nov 2014 10:29am
Spookytooth
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
See the thread '2015MY 110 - Overland Trek edition!' A buyer there swears he has been given the 3 year JLR warranty, in writing, despite 200 bhp. Note they specifically say a JLR warranty not a 3rd party warranty
Surely he is not being conned
Post #370326 8th Nov 2014 1:32pm
