![]() | Home > Puma (Tdci) > Heater only blowing onto windscreen |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 ![]() ![]() |
You will have to remove the center part of the dash and fiddle with the linkage behind the knob.
Be careful as the control comes as one unit and is expensive. You can download the service manuals containing the information you need here (courtesy of Daniele): https://onedrive.live.com/?cid=4BC2D89C85C...171%217067 |
redzob Member Since: 16 Jul 2014 Location: St. Peter Port Posts: 137 ![]() ![]() ![]() |
I had the same with mine. It went back to the dealer under warranty but i understand it was the cables that control the vent flaps needed adjusting (behind the vent control dial). Theyre very similar to bicycle brake cables where the outer shroud needs to be clamped properly for them to work. Defender Puma 2.2 XS 90
Vespa GTS 300 Way too many racing bikes. |
jwhat Member Since: 19 Jan 2011 Location: Westmeath Posts: 134 ![]() ![]() ![]() |
Thanks Lads, I'll have a try at the weekend and see if I can fix it. Tdci 110 DC
