![]() | Home > Technical > Max roof loading ? |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
What is the max for a 90 hardtop, looking at tents and such and not sure how much is safe.
Pom |
There are two figures generally bandied around. 75 and 150kg The higher figure is normally ROW whereas lower figure is Europe! Also understand Pumas are 150kg.
Remember these figures are 'dynamic' figures and are LR figures for not affecting road handling abilities. However have a look at utility company wagons and they routinely carry much higher loads. However they normally have extra front braces for the roof rack either direct to front chassis/bumper or to A pillar at base of windscreen. With LR stationary it is capable of much higher loads. Roof tents typically weigh 50-60 kg (Carbon fibre ones can save say 12 kg at an extra cost of £1,00+) If all you what is to support a roof tent consider roof bars, dependent on type say around 10kg and less then £300. Roof racks can be 30+ kg and from several hundred pounds upwards of a grand Brendan |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 588 ![]() ![]() ![]() |
Hi,
So what is the limiting factor? Centre of Gravity or The weak roof? I mounted my roof tent to the roll cage as I think the roof over time may not like the extra weight bolted to it, I know it was probably not necessary but was a nice project. I have airbags in the rear springs to help the extra weight I have added, probably 75kg. It is noticable but not a problem. Dont think I could say the same for 150 kg!! Steve ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
TDCi Manual says 150KG (330Ib) as you say Brendan - doesn't leave a lot once you have fitted a roof rack but we all know they will take a lot more. I can't find it at the moment in any of my Series brochures but I am sure the old loading rate was 75KG - will check further, it's still the same roof ![]() |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
That limit won't be dictated by the strength of the roof. It's more likely to be determined by a risk assessment of the effects on handling and the likelyhood of legal consequences, hence the different figures for essentially identical domestic and ROW vehicles. Perhaps Land Rover have realised how daft that actually was, which is why later vehicles have a higher rating.
It's safe to say that the actual limit is much higher - open any LR magazine to see pictures of expedition vehicles operating successfully all over the world - but as ever the sticking point is liability in the event that something goes wrong. If you were to have an accident where it was shown that the roof was loaded beyond manufacturers limits, then I'm sure a suitably worded offence awaits. Insurers are also likely to take a dim view. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Steve, the limiting factor would depend where you are driving.
LR are probably being conservative on their figures. Their main concern is probably road handling with heavily laden roofs going at speeds around roundabouts/tight bends CoG affects side slope ability, along with speed/hitting pothole/tree stump etc Weak roof? Roof rack say 30-40 kg, roof tent 50-60 kg is fine on road. Add 2 people say 150-200 kg when static means roof is capable of 300+kg when stationary Roof tent on roll cage transfers weight straight onto chassis Brendan |
reason for asking was I am looking at the family version of the hannibal roof tent. So potentially 2 adults a couple of teenagers on the roof. Ive had a fair bit of kit on top to be honest plus a couple of blokes on it (working on a single story roof using the roof as a work platform).
Pom |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5099 ![]() ![]() ![]() |
Roof tents and people fine like you describe at night (static vehicle fine)
But something that always bothers me, there really isnt anything to the defender - most cars have much stronger Pillars than a defender...there is almost nothing at B and C positions! Mike |
Evidence suggests some people never read the handbook & overload them regularly:
timbar Member Since: 30 Jul 2013 Location: Milton Keynes Posts: 245 ![]() ![]() ![]() |
Is that second image of an Aro, from Romania? 2009 110 XS Station Wagon
the hardtop has funny window positions but I thought it was a Series LR...
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Defender on the first photo bends more than the iPhone 6!!!
SGoggin Member Since: 04 Jul 2009 Location: Australia Posts: 19 ![]() |
I've seen a nearly new Puma which had a roof rack with some fuel up top, crushed the rear body down onto the chassis. This was due to some corrugated roads and off roading.
I'd never put a normal roof rack on a Defender, there is very little holding the roof up. That thin sheet of alloy that bolts to the rear cross member is one weakness, then at the front that's only held on by self tappers.... If I really wanted one - I'd look at one of those safety devises 6 point external roll cages, and add the roof rack to that. |
