![]() | Home > Maintenance & Modifications > How easy is it to fit an Intercooler to a Td5 with aircon? |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 ![]() ![]() |
No need to remove fan or radiator, take grill off, in do slam panel nuts from both sides then you need to take the studs out of the wings so it will lift out the way, then undo the radiator/air con rad mounts, move the air con rad forward slightly and you can get the old cooler out and new one in. It's a pretty fiddly job and you need to be careful not to damage pipes, if you aren't very hands on I'd probably advise getting an Indy to do it or have a mechanic friend close by
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Thanks for the reply bga. If I can get away without removing either of the rads, I feel a bit more confident about tackling the job myself - just take it nice and slow.
Now to decide on which intercooler to get. The Alive one looks nice. |
Chocolate Member Since: 18 May 2012 Location: Berkshire Posts: 153 ![]() ![]() ![]() |
Hi Hufflepuff,
I did mine last year, Allisport intercooler. Getting the slam panel off is fiddly but not too bad. I changed the hoses as well. Getting the old intercooler out is hard especially as the hose clamps are installed before the wings are put on. So I had a very hard time trying to reach one. It took me a while to undo this. There isn’t a great deal of room to do up the new ones either. It’s a very satisfying job to do. I wasn’t happy with one of the hose clips so I ended up unbolting everything again. Allisport have instructions on line on how to do it all. I had to cut one of the plastic brackets for the intercooler to fit, don’t know if you still need to do that. Took me around 4-5 hours in total, but then I wasn’t going fast and ended up spraying waxoil to parts that were hard to get to while things we off. ![]() |
This has to be one of the most friendly and helpful car forums I've ever come across! Thanks for your advice Chocolate, I'm getting more and more confident about doing the job by the hour
