![]() | Home > Puma (Tdci) > SSM38428 - P1169 and or P0089 codes logged. |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
This issue has been commented here, but I think that can help somebody.
Regards Models LD - Defender Title P1169 and or P0089 codes logged. Last Modified 30-JUL-2008 10:16 Category Driveability Symptom 608000 Runs Rough Content Issue: 07MY onwards - Difficult to start, missfire, lack of power, driveability issues etc. PCM can have either P1169 and or P0089 logged codes. Pre assured Vin# Def 90 at Vin LD8A760582. Defender 110/130 at Vin# LD8A760304. Cause: Potential contamination in the fuel system. Action: Remove the fuel filter, drain complete contents into a suitable clear vessel. Note signs of any water contamination / debris. 1) If more than 40cc of water or debris is evident carry out the following:- Drain the fuel tank. Check the fuel tank breather location and reposition as per the illustration A attached. On pick up variants please reposition the breather pipe in board towards the rear of the fuel tank. If breather is blocked replace the pipe as per GTR. Replace the fuel filter and clean out the fuel lines of any contamination / debris and or residue. For P1169 code replace the FMV (Fuel Metering Valve), as per GTR and LTB00153. Illustration B. If DTC P0089 is also present replace the PRV (Pressure Relief Valve), as per GTR. Illustration C. Bleed and prime the fuel system as per GTR. Start the vehicle and carry out the pump learn process with IDS as per GTR. Carry out a road test to ensure the issue has been rectified and no codes have been logged. Submit any findings on ePQR to engineering. 2) If no sign of water or debris but either codes logged carry out the following:- Check the integrity of the wiring and the condition of the terminal connections between PCM and Fuel Rail Pressure Sensor and between PCM and FMV. Repair wiring as necessary and re test the vehicle. If no issue is found with the wiring / connections, and code P1169 logged, replace the FMV as per GTR and LTB00153. Replace the fuel rail PRV (Pressure Relief Valve), only If DTC P0089 is present as per GTR. Start the vehicle and carry out the pump learn process with IDS as per GTR. Carry out a road test to ensure the issue has been rectified and no codes have been logged. Submit any findings on ePQR to engineering. Note:- A new tank / breather design was introduced on Defender 90 Vin# LD8A760582. and Defender 110/130 at Vin# LD8A760304. Please submit an ePQR for any issue seen on vehicles post these vins. Also there is some pictures attached to the SMM Figure 1 ![]() Figure 2 ![]() Figure 3 ![]() Figure 4 ![]() Click image to enlarge Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Excuse my ignorance but does this look like 40cc
![]() Hope not. The container is about 50 x 50mm and 10mm heigh with water. ![]() ![]() Series III 1973 - going strong |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Do you think it is still safe then?
I did relocate the breather already and subsequent tests have not revealed any more water, only some left over silt from the time we traveled 6 hours on wet dirt roads. I have not had any symptoms of power loss or higher fuel consumption etc as yet. Is it worth taking up with LR and show them the sample? I am not sure they would apretiate me taking a sample myself. i am also lucky I didn't get an air lock as at the time I had no manual and thought she had a pump in the tank. How does one change a filter in the outback if you don't carry special bleeding gear? Chers James Puma 110 - gone Series III 1973 - going strong |
Yes, that's a question I too need an answer for. I somewhat blindly bought a spare fuel filter but now don't know how to change it if I ever had to (dirty fuel etc). I'm still to subscribe to LR GTR. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
Any idea where it goes or how it works?
Looks like it may connect to the drain and suck fuel from the tank into the filter. Could one not fill the filter element with diesel and screw it carefully into position? Puma 110 - gone Series III 1973 - going strong |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
It plugs into the injection pump supply line on the engine via a quick connect coupling. It works as a suction pump and bleeds the fuel by sucking it through the filter, up to the engine, through the tool, and then returns it back to the tank through the fuel return line.
Cheers, Tim |
does that mean the outlet of the pump also has a quick coupler into the return line? Puma 110 - gone
Hi CapeLandy, here's the instructions out of the "book":
http://www.defender2.co.uk/gallery/albums/...ing%20.zip Cheers, Tim |
Thanks Tim, the down side to the reply you got is three letters - SPX - in my experience this spells something twice the price of Snap-On tools in Australia
![]() I suspect that this must be a standard TDCi component, so there's probably a generic one on the market. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
Thanks Tim
Just got hold of two local dealers who said "huh?" when I asked for the price and availability of the tool. Called Landrover South Africa for their responce - still waiting for a call back. Will let you know of the answere I get - could be an interesting one ![]() I mean, how can a dealer not keep this tool for the public to buy. Imagine getting stuck in the middle of the Okovango Delta and no way of getting her started after changing the filter because you got a bad load of fuel from a remote garage selling fuel out of coke bottles. ![]() Cheers James Puma 110 - gone Series III 1973 - going strong |
