![]() | Home > Tdi > 300tdi no power/grunt at low revs |
| NickH Member Since: 02 Nov 2014 Location: Halifax Posts: 204
Hi Souster4
It could be the lift pump again, start it up, let it run for a few secs, turn off and check if the fuel filter is full. For some reason 300tdi lift pumps are not very good whatever make they are. I have had a few turbos start to seize up on 300 s , engine off, remove the pipe and spin the turbo shaft. It should spin nice and free, if its a little bit stiff/sticky that maybe making it lazy at low revs. The reason I said check lift pump first is because the turbo wouldnt really make it stall. Hope this helps 2003 Td5 90 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
